Caporegime
- 20 Oct 2002
- Wish i was in a Ramen Shop Counter
You get one epic moment per series, because that's the budget limit.
The pacing problem is down to two things:
1) Yes, Martin's books are way too long. And much of that is padding which simply doesn't go onto screen. But then I think the whole Danearys and Wall arcs are completely padding, and only the War of the Five Kings is worth following. But even if you like all the arcs, the padding is most of the books.
2) By putting the Red Wedding (which takes place about two-thirds of the way through book three) at the end of series three, they left a whole series to be filled with a third of a book, plus a bit of book four. But there's very little from book four that they can put in this series, because a large amount of books four and five (they take place simultaneously for a while) is just starting various sections of the overall arc that will not be completed until at least series five. That leaves a LOT of time to fill in. Hence the stupid Craster's Keep section, which is just an expensive shaggy dog (not Shaggydog) story.
It get worse, because there is at least one big moment that they will probably put in the second last episode, as is usual way. Which means even less of book four and five can be put in. Hence even more padding.
Whatever happened to "oh there are so much material in the book that they can't fit it all it, it's like 800,000 pages and we only got 10 episodes".
Padding? WTF it sounds like nothing actually happened in the books at all and that they are making up stuff to fill the time.
Wait, that's what I said last year! Lol
That's how I felt when they show scenes that didn't move the story along. How they keep repeating some scenes. I'm glad you guys finally see it now!
Btw, epic moment doesn't need to be fights with a billion soldiers, the red wedding was done with like 100 or so casts, Joffery's death was about the same and no fighting, stark's head on a block, these are epic moments. I merely like things happen on screen for a reason, filler scenes or filler episodes in a show that has only 10 shows in a season as opposed to 22-24 is a joke. Why not just cut it down to 6, more budget then for the rest and make it more epic? You cut out the crap, make the good ones even better. (Yes I know that's not going to happen, but those that constantly tells me there are so much of the books being left out when they keep doing these fillers).
