Man I'm getting withdrawal symptoms. Can't play as working away from home![]()
That isn't how you do it (according to the guy), as when you go into the game on a different char you'll have a new loot table.
You get someone else to make a game at the level you want, then you go in on the char you want the gear on, kill stuff, kadala, blah, blah, blah.
I don't believe what he says at all anyways tbh, he provides no evidence at all.
Might try the same thing Eulogy, need needing a decent amulet slot. 20 shards a pop thoughso little wonder i get anything from gambling.
Congrats on the second unity. Let me know how it goes if you try it out on a higher torment level as I am still waiting on my second unity. I think I would be pretty survivable but I have a feeling my DPS might make it a little bit of a slog.
Yeah, the 20 shards for an amulet is tough to swallow. I am still looking for a good one and can't bring myself to gamble for the amulets yet.
I don't mind A1 but some of the bounties can be downright annoying, like the spider caverns, or running around the big fields of misery.
Just do act 1 caches. Gorget of Leoric rolls nicely as you are guaranteed a primary stat (not vit) and crit chance. It also rolls with all resist that you can reroll into either crit damage or elemental damage. You just need the 1 random primary to roll a DPS stat and you have a great ammy. In the mean time you can get blood shards to do some gambles for an ammy if you want and probably some drops here and there.
snip!
Thanks for the advice mate, didnt realise there was a amulet specific to act1 like Rrog. So chance to get it from the act 1 horadric caches.
Do you guys run act 1 bounties on normal or torment? Does diffculty actually affect the drop chance and quality of the item ?
