IC-Diamond GIVEAWAY Thread!
Awesome! Hope I was in the first 100. I sent via the 'Email Address: Click to send a message', rather than directly to the Yahoo email addy. Hope that is right as I haven't received any confirmation or anything.
I did the same and no confirmation recieved...
edit:
I do not have time to confirm every trust im afraid.
However if you are outside of the 1st 100, something can be arranged I am sure. Let us get the first 100 completed in this instance.
fingers crossed then, #106 :(
Mine arrived today, thank you again Frostdragon :)
I tested it over the two hours, checking idle temps and running prime for an hour to put a bit of strain on the CPU, then stripped and cleaned the old paste off the CPU/HSF before applying the IC-Diamond.
CPU: i5-2500k @ 4.2GHz
HSF: Arctic Freezer i30 w/ stock fans
Old compound: Arctic MX-4
Ambient Temps: 18.5-19 degrees C when testing with Arctic MX-4, 20-20.5 degrees C when testing with IC-Diamond.
MX4 Load:
IC-D Load:
IC-D Idle:
I seem to have lost/not saved the idle temps with the old Arctic MX-4, but I was watching it closely and was getting temps sitting around the 29 degree C mark.
Fantastic stuff, lower temps which is always a great thing. I would have loved to test on my GFX card, but it's still under warranty and I can't remove one of the screws without removing the warranty sticker :(
Tidy #53, going to do some benches tomorrow and then redo them when I recieve whichever one gets sent.
