A full repair sets you back like 50k ish? You'll pick that up after a good pull easily.
I just wouldn't gear around durability loss.
I guess repair costs differ? Repairing from Red on T4 costs about 200k.
Not really sure how I should be spending my paragon points either.
Gold ain't an issue anymore now the gold find changes have been made. Made about 10m yesterday in no time. That was only T3 as well. Get piles of 25-30k on T4 I think, maybe higher. Wasn't paying much attention.
. It's good, better than the Condemnation I've been using, but without the extra disc/hatred regen on the Condemnation my damage output drops as I don't have the extra Preperation
unishment
.When/how do you earn Paragon points? I'm not quite L70 yet - assume it's after then and if so, does it matter whether you are on the bounties or main campaign?
Yeah.....nowhere near T4 - I'm barely holding my own on Expert!![]()
You start earning paragon points when you are 70 as you still "level". Every level you gain gives you a paragon point, which you spend in one of 4 tabs on various abilities (very minor buffs that have 50 stacks each).
In other news, my WD is now on 999,969 sheet dps, so close to 1mil! lol
.Think I'm going for this on my Wizard
http://us.battle.net/d3/en/calculator/wizard#URQSjT!SXTY!YYZZaZ
Can't really see anything else that looks like it'd work.
Looks pretty good - although I'm not quite understanding the benefit of the "Wormhole" rune on the Teleport skill "After casting teleport, there is a 1 second delay before the cooldown begins, allowing you to teleport again" - does this mean that you can teleport twice as long as you don't take more than 1 second to do it??![]()
Also, Noxxic is a horrible website. They just copy and paste guides from other places and don't keep them updated either.
You could check out the wizard specific subreddit which has some guides on the sidebar. http://www.reddit.com/r/Diablo3Wizards
Or you can try some of the builds posted on Diablo Fans which are always good quality and normally accompanied by a video guide/demonstration http://www.diablofans.com/guides
The only stat you need to worry about is elemental damage % for the skills you're using, all the other stuff like crit hit damage, crit chance, attack speed is always best to have as much as possible.
