Very happy with my Crusader now. Torment 5 is a stroll without using 2 Unity's and rift runs take 5 - 10 minutes (depending on mob types / map / density). Need some similar stat Akkhan boots, some Str/Crit/CritD/CDR gloves and I might go back to a Hellskull which'll put me at 5 seconds downtime of Akarat's Champion. Probably a Cindercoat too if I can get a good one. Currently having an issue where Akarat's Champion wears off and I have 10 seconds before I can use it again, and in that time I run out of Wrath in about 3 - 5 seconds so have to waddle around a bit or scramble for globes as I don't use a builder.
It's depressing that my 70 hour Crusader can do T5 effortlessly and my 750 hour Monk can't. Doubt 2.1 will be any time soon either to fix that.
So my RRoG
I really can't decide what to do with this. Either way I'm going to lose crit hit dmg or crit hit chance but I can't decide which one I can afford to sacrifice. I really do need it though because of the reduction of set bonus.
52% crit hit chance and 406% crit hit dmg overall at the moment. I think it'd be best rolling the life on hit for crit hit dmg?
As said above I'm best putting in a high int gem in the socket?
Yeah you would be nuts to do anything else with it. Roll the Life on Hit for CHD %, as close to 50% as you can get. Put in a big int gem, the most you can afford.
It will still be reasonable. Crit % is easier to get so CHD % is better. However if you happen to get Crit % in the first few rolls and you don't have much cash it's not too bad either![]()
Wow, Smudge said he was power leveling your crusader the other day, can't have been more than a week ago now, how on earth have you put in so much time already?
Roll to Magic Missile dmg % is probably best, as you would always gain benefit then of +2 Magic Missiles AND Magic Missiles doing 15% more dmg so matter your spec!![]()
Try with and without, but yeah you may lose 10% sheet but gain 16% fire damage, which should be good. However that is not a great set of Magefists tbh.
You ideally want:
Fire %
Int
Crit %
CHD %
Attack Speed
That is what they call trifecta, as you get the 3 main damage increasing stats.
I wouldn't spend more on your ones really, as you should be able to find a better set![]()
Yeah man keep it up!
Magic Missile with +2 MM from Mirrorball is really powerful by itself tbh, you'll probably find it's one of your main dmg dealers and doesn't cost anything extra. I don't know what sort of build people use in T6 with fire gear but aim for the kind of stuff they wear.
I would guess that strongest is 3 piece Vyrs with RRog with 2 piece Aughilds (helm/shoulders/bracers, any 2 of those) with enough CDR to get Archon on a short enough CD to use very often.
Wiz has a passive for an extra 20% CDR so you can get a lot of it.
Really good/easy places to get CDR initially - Diamond in helm gives 12.5%. Shoulders with Int/Vita/All Res and 8% CDR are ideal.
You can get 8% on rings/amulets too, though arguably rings are better as you can roll key stats on amulets and the CDR % value on them both is the same.
