- 4 Oct 2008
- London
I have found multi monitor support to be ok at best and woeful at the worst of times, I have only owned a OSX device since Mavericks and from reading reviews support was much worse per Mavericks.
There are a few other issues I have faced, as a whole I really enjoy OSX but it has had a lot of bugs, moreover with multi monitor.
Sticking too the OP, I don't mind about minimise and such as I just use hotkeys for all that, its a lot more consistent and it allows me to keep my hands on the keyboards.
Battery life has been awesome for me, I would recommend taking a look at apps like CocobutBattery and seeing what they report. I get a solid 10hours using Chrome. A lot of people bitch about battery life on chrome but it is just as good, but you can install 120312 plugins and make it need a lot more resources, if you have a sensible amount of plugins its solid. It also sandboxes Flash which is a plus. Also dislike the UI on Safari, its overall metal design, doesn't have favicons in the tab bar, the whole tab bar idea is nuts, I don't need it full screen tab bar when I have 2 tabs, and chrome works on all my devices.
Keyboard was ****ing annoying, I hate apple for switching things like the @/" out of sheer arrogance to not produce a standard UK keyboard, **** em for that. I'm used too it now, but I hated that I had too.
Also dislike how everything has to basically run through Thunderbolt, without any ports included. My friend got a Sony Vaio Pro and it came with so many ports, a mini ethernet too ethernet, hdmi/dvi -> mini DP, even a mini portable WiFi station. With Apple you have to pony up £30 for every thing and it makes it difficult not to think Apple makes some choices purely to get more money out of users.
Everything else about OSX I really enjoy, I get a real terminal compared to Putty, omg godsend. Scaling actual works, I had a SP2 before and it was not good, I have not had a single scaling issue. Hardware is awesome, price now is very competitive.
Battery life has been awesome, love the display, I like how consistent apps are e.g. I can hit cmd + , in any app and open the settings page. Apps are generally better designed, and I've not seen one piece of crapware trying to trick me to install it along with an app. App store is not bad, sandboxing means most of the apps I use I have to get direct from the developer thou so it is sort of lost on me.
All in all its been good, hopefully 10.10 fixes some of the stupid bugs/crashes I get, its not be as stable as I hoped for but I get a lot more done a lot faster then windows, and it has been more stable then my experience with linux.
- Simple things like my dock magically disappearing (My monitors at work are 16:10), or appearing when I take an app full screen.
- Wallpapers are hell, I recently tried to change my Wallpaper, so I changed it on all monitors across all my work spaces. Turn laptop on the next day and it has a mixture of all wallpapers I have used since the day I got my Mac. It shoulnd't be so hard to change a wallpaper, and I always have issues with it
- If I put my Machine to sleep before I unplug my display, when the machine is woken up next it still assumes the display is connected, all my windows will be spread across the displays, and my mouse can freely move off screen to where the displays where last positioned. Pretty annoying bug as I like to close my lid before I remove the cables at work.
- Dragging a app to another windows doesn't automatically make it fixed to that display e.g. I can move PS from my Laptop screen to Monitor 1 but all daliogs, until I manual switch it in the dock.
- I appreciate what you're saying, however any issue you throw into google you're bound to find others having it and someone claiming it to be an ongoing bug/issue etc when it might simply be a small handful of people with an underlying problem causing these bugs.
