**The New Official THIEF-Incorporating Bench mark Thread**
Lol... Done :)
Just to get your mouth watering... not an entry though.
Done. wow, :) Matt how did you get your 290 running at 1250?
With +175mv. It will go higher but its far too hot so temps go up and fps go down when my gpu's get hot. Someone with a better cooled 290P or even a 290X will beat my scores don't worry.
Thats pretty good. i need +200mv for 1225.
I just completed a run with 1250/1625 at 1440P with +150mv. I can probably fine tune voltage, brings temps down a tad and get slightly higher fps. I've had enough now though for today and will submit a 1440P bench shortly. I will wait for a cold day and rerun my 1080P bench as well because i used higher voltage for that.
You have done well :)
[email protected]
290P crossfire @1250/1625
14.6 Beta
DirectX
This is an entry.
1080P
1440P
My DX scores are crap. Low gpu usage is the problem at 1080P.
EDIT
I also have a lower minimum fps at 1080P than i do at 1440P? :confused: :D :rolleyes:
