- 25 Nov 2011
- The KOP
Mantle kicking some api butt
Well done amd and thief devs.
Damn impressive matt!![]()
Whyscotty said:4770K @ 4.7 TitanSli @ 1280/1895
1080
Matt how did you get your 290 running at 1250?Done. wow,Matt how did you get your 290 running at 1250?
With +175mv. It will go higher but its far too hot so temps go up and fps go down when my gpu's get hot. Someone with a better cooled 290P or even a 290X will beat my scores don't worry.
Thats pretty good. i need +200mv for 1225.
I just completed a run with 1250/1625 at 1440P with +150mv. I can probably fine tune voltage, brings temps down a tad and get slightly higher fps. I've had enough now though for today and will submit a 1440P bench shortly. I will wait for a cold day and rerun my 1080P bench as well because i used higher voltage for that.
Done.
Humbug you made a mistake on my minimum fps of my 1440P bench.
