AMD Catalyst 14.6 Beta Driver for Windows out now
3 Dec 2010
Hi
Did anyone get watch dogs running with a 7990 if so what settings and how,
mine runs like garbage 25-30fps both gpus at around 40load
thanks
maka
26 Sep 2013
West End, Southampton
Here's something interesting guys. On 14.4 RC1 drivers, with 1100/6000 clocks on my cards, I passed 3600 points in Unigine Valley. With the new 14.6 driver and the same settings in CCC and clocks, I scored 2562 and 2596 2 tests. That's a thousand points drop, which is huge.
Anyone else done some proper benching on these drivers and not caught up in Watch Dogs performance?
Might roll back to 14.4rc1 and bench again. weird.
Caporegime
17 Mar 2012
ARC-L1, Stanton System
Valley is bottlenecked by my CPU but i can give it a go.
16 Mar 2009
Hi everyone,
installing these drivers gave me an issue, basically after installing they seem fine then once I reboot my PC starts loading, I see the windows loading screen but then it all goes black, all I can see is my cursor over a black screen. This is where the password screen for my login would usually be.
I have tried this twice now. Uninstalling CCC and drivers via windows uninstall, then a reboot, then driver sweeper to catch anything, reboot, install 14.6, installs with errors like every new driver I get but nothing that stops them working (error log looks like a load of messy code) then next time I reboot I get a black screen.
Any idea's? I have to get into windows recovery and do a system restore just to get back ontpo my desktop...
10 Nov 2013
14.4 13296
http://www.3dmark.com/3dm11/8346818
14.6 13806
http://www.3dmark.com/3dm11/8370756
heaven 14.4
heaven 14.6
Caporegime
12 Jul 2007
United Kingdom
I found something interesting with these drivers. I've had to increase my voltages or i get a black screen when idle. I've had to increase voltage two notches from my previous undervolted settings.
6 Jan 2011
bristol
i got in a right state installing these drivers, system just hung and had to turn off pc then i could not even install the old drivers, in the end i had to do a system restore which sorted it and im now back up and running, i think i will leave the old 14.4 for now
9 Dec 2006
@ManCave
Hi
thanks
maka
Mines running 60-90FPS now After much playing around
Crossfire ON
i7 3770k @ 4.2 (no difference to 4.8)
Textures set to High - Ultra Kills Vram to Quick
GPU Max Frames 3
Level Detail - Ultra
Shadows - High (looks no different to Ultra)
Reflections - High (looks no different to Ultra)
Ambient - MBHAO (HABO Looks worse, i think its Nvidia only to?)
Motion Blur - Off - Hate it
Depth of Field - Only seem to make difference in cars. so turned it off
this driver also fixed
My 16:9 21:9 16:9 Resolution issues
26 Sep 2013
never mind guys, I Was being a total NOOOOOOB
I had SuperSampling enabled in CCC because I was messing around with it on in Watch Dogs lmao. Just got in and done a proper run with Unigine Valley and made a 3641 score so a new high for me :)
Permabanned
30 Apr 2014
On 14.4 temps on Crysis 3 would go no higher than 80c at 40% fan speed but with these drivers they increased to 84c. I can't see any difference in framerate.
Went back to 14.4 and back to normal. Does anybody else notice a increase in temps with these drivers?
