I tried doing T6 in a group with my DH - was getting one shotted by the rift guardian,or some of the blues if I could not kite away from them.
Either I need more toughness or I need to up my damage.
I have very good gear on my mages and still get 1 shotted on bad packs on t6. Did a bunch of runs with hh and a few others from here and we smashed it, did some with another group and died a lot. I think it depends on who your with unless your solo and having problems? Solo I do t5 for speed myself. Can do t6 but can pretty much shave 40% clear time off dropping 1 level.
. Once I get my Harrington's (bloody thing won't drop for me) and maybe another Unity T6 should be viable. Or I could get some sort of Pride of Cassius build going (the 4 second Ignore Pain belt) as that'll mean I'll stun for 3 seconds on leap land, then ignore pain once they're onto me by which time T6 stuff should be dead.
Having fun on WD though, once you get all the little guys out its hilarious, stuff just melts, pop BBV and its crazy.
Get the full Marauders set, my brother's DH destroys T4/5 and T6 will be viable with a bit more DPS which he can get with a few better rolls etc.
You need enough toughness to take a couple of shots just in case, but generally the aim is to kill them before they kill you, especially in T6.
Now imagine you have 4 pieces of zunimmasa's set (or 3+ring), starmetal kukri and carnival mask ;] small army of shooting psychopats with endless BBV...nothing can stop you.
and Zuni offhand, i picked up a nice SoJ yesterday but it was cold based, so banking it if i ever get enough Jade to run a dot build, i have Quetzl in the bank also, i think the only Voodoo mask i dont have is Carnevil actually.I hear its not worth using 4 piece Zuni though til they fix the proc on it as it currenly overwrites FA fetishes.
To spawn the yellow arrow just visit all the quests one after another, then start doing the first quest.
By the time you finish it, the remaining 4 quests should have spawned the arrow.
Recently found out about this rimeheart shattering build for monk that is viable for T6 solo. Problem is it's basically the rarest 1 hander in the game. 1% drop rate for 1 handers
Guestimating at approx 1 legendary 1 hander every thousand shards from kadala you are talking 100k shards gambled before you could expect to get one.
So yeah...
I have RRoG on my WD, have Zuni helm thoughand Zuni offhand, i picked up a nice SoJ yesterday but it was cold based, so banking it if i ever get enough Jade to run a dot build, i have Quetzl in the bank also, i think the only Voodoo mask i dont have is Carnevil actually.
Still hoping to get a Tallmans finger, debating what element to spec also for pet build, Fire could be good if i can find a Cindercoat, Fire neck, fire bracer, fire SoJ.
Seems for Pet doctors, Physcial, Fire and Poison are all valid specs now
