Caporegime
- 13 May 2003
- Warwickshire
No, you will be limited to 125cc/a power limit that I can't remember (11kW?).
Thanks, that's what I thought, but provisional code A is described as follows:
- A motorcycle of a power exceeding 35kW or with a power to weight ratio exceeding 0.2kW per kg, or
- A motorcycle of a power not exceeding 35kW with a power to weight ratio not exceeding 0.2kW per kg and derived from a vehicle of more than double its power.
Also here: https://www.gov.uk/driving-licence-categories
Now I'm probably being thick, but that wording seems ambiguous in that it states that I can provisionally drive a motorcycle of a power exceeding 35kW. Then it says 'or a motorcycle not exceeding 35kW'...
The word 'or' makes zero sense in this context to me, as it negates the previous bullet point!
. The question is - what does 'provisional - A' actually mean?
h and I definitely need to buy some summer gloves, I used the gloves I bought a while ago (I was unaware of seasoned gloves I have winter gloves), sweaty sweaty
