3DMark Sky Diver Benchmark Thread
Man of Honour
21 May 2012
Dalek flagship
Simple Rules.
If your CPU has integrated graphics please remember to turn this off.
No entries with the time data error message can be accepted.
Please don't forget to post your CPU and GPU clocks.
Please also post your Sky Diver preset link.
2160p Challenge Settings.
If anyone wants to give it a go the settings are below.
Graphics Scores only will be used for the scoreboard.
1. Reset to Default in the custom settings.
2. Raise resolution to 3840 x 2160.
Download.
Scoreboards.
Thread Navigation Links.
Might want to consider listing by GPU score instead of the overall score because with high end GPU setups this is going to be a CPU bench instead of a GPU one.
Yeah I know but I was suggesting the use of GPU score for determining how a submission ranks in the lists.
Because if you use overall score for the ranks here you're going to end up with a list that shows who has the fastest CPU with the most cores. How fast your GPU is will be mostly irrelevant.
What I will probably do is have a top 20 of the best Graphics scores listed in a separate table if we start getting a lot of entries.
I do agree with what you are saying though as from personal experience it is quite annoying having someone who used LN2 on the CPU listed above me even though their GPU score was lower.
Is this currently bugged for Nvidia?
Graphics test 1 was nothing but a black screen.
Regardless of that I have a 4770k and GTX780 Classified. Neither is overclocked by me so there on there out of the box clocks.
score = 24571
Graphics = 36160
Physics = 9993
Combined = 20217
http://www.3dmark.com/3dm/3240039?
Okay, Cheer's Gregster & Kaapstad.
score = 24571
Graphics = 36160
Physics = 9993
Combined = 20217
I also got a black screen on my GTX 690s but the bench still completed.
I think there will be a patch soon.
Haven't even run benchmark, but in demo it got to a scene where she enters a cave I think and it went black screen, sound still working! I alt tabbed out and loaded task manager - 3DMark is not responding! Couldn't even quit as my mouse icon had disappeared so I had to manually log-off and log back in. Bot sure if it was a 1 off coz haven't retried it and currently playing Batman.
If you run the benchmark (black screen as well) it should still run all the way through and give you a score at the end. I think the GPUs are working correctly but they are just not outputting to the screen.
