Namrata:Hello, my name is Namrata. I will be glad to assist you.
Could you please elaborate your concern please?
Me:I have had my Asus monitor I purchased from you with clearance from Asus to obtain a refund.
Namrata:I understand that you would like to return the item "Asus PB278Q 27 inch Widescreen LED Multimedia Monitor (2560x1440, 5ms, VGA, DVI-D, DisplayPort, HDMI)" for full refund. Is that correct?
Me:I have already returned the item to Asus, they have accepted the monitor and issued clearance for a refund.
I have the credit number: xxxxxx
Namrata:Okay, Could you please let me know the order number for the same?
Me:#202-0823564-2097926
Namrata:Thank you.
Me:No problem
Namrata
lease allow me a minute while I check this for you.
Me:Thank you
Namrata:Thanks for waiting.
I am really sorry for the inconvenience caused to you. I would like to inform you that You need to contact Asus because you have returned the item back to the Asus so they are able to issue you the refund or replacement as per your preference.
Me:They said the opposite, Asus do not issue refunds directly. I will quote email
"Thank you for your patience regarding the credit back for your ASUS monitor.
The credit number has been issued.
Please contact your seller to advise them of the credit number: xxxxxx.
With the above, they will be able to contact the distributor for the credit to be issued to them and yourself."
Namrata:Thanks for the information Jonathan.
Me:also another quote from Asus "the credit needs to be claimed with the reseller who is provided with the credit by the distributor.
ASUS will not issue the credit directly to yourselves."
Namrata:I am really sorry for the inconvenience caused to you. Please contact the Asus to send you the return of the item and then you can return it back to us so than we are able to issue you the refund.
Me: The main reason I had a refund is because they send me 4 defective monitors, so returning the one I originally sent back 2 months ago will not be possible.
Do you not use the credit number to contact your distributor for Asus who will then release the funds to yourselves?
Namrata:I am really sorry we don't have the option to use the credit number to issue the refund. In that case, I would request you to please contact Asus, and return the item back to us so that we can issue you the refund.
Me:I will contact Asus and see what they have to say, thanks for your assistance.
