PLEASE NOTE, THE TIMES HAVE CHANGED FROM 11AM TO 9AM TO ENSURE PEOPLE ARRIVE FOR SHOP OPENING AND DON'T MISS DEALS
Hi there
OK yes there is a catch, its called an AMD IN STORE EVENT which is 11am - 4pm (Shop opens at 9am) on Saturday 28th June. This is similar to our original opening event where quantities shall be limited, but in short we will have the following truly INSANE deals for you IN OUR SHOP ONLY, you can't buy online, I REPEAT NOT AVAILABLE ONLINE.
**One Deal Per Person of the below deals**
Sapphire AMD Radeon R9 295 X2 OC 8192MB GDDR5 PCI-Express Graphics Card - Metal Box LTD Edition @ £759.99 inc VAT
No matter what the game or the resolution you can now select the maximum settings even at 4k resolution and enjoy fluid ultimate smooth framerates in latest games such as Titanfall, Diablo 3, Watchdogs and even potential upcoming games such as GTA V and Half Life 3 should they surface.
Featuring a pair of 290X Hawaii GPU's fused onto a single PCB with an advanced PLX chip along with only requiring 2x 8-Pin power connectors.
The other major feature of the 295 X2 is its cooling solution which truly does keep the cards temperatures around 60c even after gaming for hours and it also manages to do this in more or less silence with zero throttling of the cores themselves. Making it one of the smoothest, quietest and easily most powerful graphics card on the market today. If you really crave the most powerful and have or are considering a 4k monitor for gaming then the 295 X2 is the card for you.
If your demands are truly the most powerful experience possible then these cards work great in Crossfire (4 GPU's) and you will be able to smash benchmarks to pieces and have no slow downs in games.
Specification:-
- GPU: 2x Hawaii XT
- Hybrid Liquid Cooling
- Litecoin Hash Rate: 1600-2000
- Stream Processors: 5632
- ROPS: 128
- Core Speed: 1030MHz
- Memory Speed: 5200Mhz
- Memory interface: 1024-Bit (2x 512-Bit)
- Memory capacity: 8192MB GDDR5
- PCI-Express X16 lane required
- 850W or greater PSU required with genuine 8-Pin PCI-E cables such as Silverstone 1500W
- Case capable of fitting such a long card and support for a 120mm radiator
- Dimensions: Card is 307x111x65mm and Cooler is 153x120x63mm
- Power Connectors: 2x 8-pin
- Display Outputs: 1x Dual Link DVI, 4x Mini-DisplayPort
- Warranty: 2yr
Was [£1099.99] Inc. VAT
Only £759.99 inc VAT - ONLY 5 UNITS
ORDER NOW
Sapphire Radeon R9 290 Tri-X 4096MB GDDR5 PCI-Express Graphics Card (11227-03-40G) @ £199.99 inc VAT
AMD Radeon R9 290 is a new graphics card powered by the latest AMD Radeon™ R9 290 graphics-processing unit (GPU). 4GB of super-fast GDDR5 memory for the best gaming experience at the highest resolutions including 4k and incorporates AMD Eyefinity and TrueAudio technologies to enable expansive multi-display setups and more accurate environmental sounds. R9 290 also includes support for both DirectX® 11.2 and AMD's new Mantle application programming interface (API) for great handling of even the most-demanding PC games.
Specification:-
- Radeon R9 290
- GPU: Hawaii Pro
- Litecoin Hash Rate: 800-950
- Stream Processors: 2560
- Core Speed: 947MHz
- Memory Speed: 5000Mhz
- Memory interface: 512-Bit
- Memory capacity: 4096MB GDDR5
- 600W or greater PSU required
- Power Connectors: 8-pin + 6-pin required
- Display Outputs: 2x Dual Link DVI, 1x HDMI, 1x DisplayPort
- Warranty: 2yr
Was [£319.99] Inc. VAT
Only £199.99 inc VAT - ONLY 15 UNITS AVAILABLE!!
ORDER NOW
Asus Radeon R9 280X DirectCUII TOP 3072MB GDDR5 PCI-Express Graphics Card @ £149.99 inc VAT
The next generation Asus R9 280X DC2T graphics card has arrived, fitted with a 28nm GPU that packs 4.3bn transistors and is combined with 3GB GDDR5 Memory, it provides users with the speed for smoother gaming. Supporting full DirectX 11, AMD CrossFireX and AMD HD3D, the GPU includes an exclusive tweak utility which allows users to tune the performance of up to four graphics cards and check card status via an intuitive interface.
This GPU Tweak function links the GPU clock frequency to the voltage, so as you scale the GPU clock the voltage automatically follows; a useful tool for inexperienced Overclockers, It also enables users to select between 2D and 3D mode by providing the ability to change the respective clock speeds, voltages and fan speeds of either. Disabling the 2D mode also forces the faster 3D mode, stabilising overclocking and benchmarking results.
Embedded with GPU-Z to access accurate graphics card information, the card also contains a live update driver and BIOS benefiting users with the ability to keep their card in the best condition. Widget monitoring provides the choice to display the most needed information including a full widget, light widget or real time monitoring.
Furthermore, new PCI Express 3.0 delivers improved encoding and twice the performance of the previous PCI Express 2.0 and vision horizons can be expanded across six displays with AMD Eyefinity technology. This technology delivers innovative graphics display capabilities enabling massive desktop workspaces and ultra-immersive visual environments for the ultimate panoramic computing experience.
Specification:-
- Litecoin Hash Rate: 550-750
- PCI-E 3.0 Ready: Delivers double the bandwidth per lane of PCIe GEN2 for faster GPU- CPU
- Hugely overclockable
- Core Clock Speed: 1070MHz
- Shader Architecture: GCN
- Stream Processors: 32 CU / 2048 ALU
- Texture Units: 128
- ROPS / Z-Stencil: 32 / 128
- Frame Buffer / Memory: 3GB GDDR5
- Memory Width / Speed: 384 bit / 6400MHz
- Load / Idle Board Power: <300W / <3W
- Display Outputs: 2x DVI + 1x DP + 1x HDMI
- Power: 250W TDP
- 3yr Warranty
Was [£239.99] Inc. VAT
Only £149.99 inc VAT - ONLY 10 UNITS AVAILABLE!!
ORDER NOW
MSI Radeon R9 270 Gaming Edition OC 2048MB GDDR5 PCI-Express Graphics Card @ £99.99 inc VAT
A graphics card is the single most important element for more FPS. As gamers, we understand that not just any graphics card "will do". That's why we bring you the best of the best. We don't want to bug you with noise and heat, but we DO want to give you more performance. With MSI GAMING series graphics cards you get just that.
Was [£131.99] Inc. VAT
Only £99.99 inc VAT - ONLY 10 UNITS AVAILABLE
ORDER NOW
Sapphire Radeon R7 265 Dual-X 2048MB GDDR5 PCI-Express Graphics Card @ £109.99 inc VAT
The SAPPHIRE R7 265 Dual-X has 2GB of the latest DDR5 memory clocked at 1400MHz (5.6GB/s effective) and core clocks of 900MHz (925MHz with dynamic boost) to deliver new levels of performance in its price segment. Performance is optimised with the latest version of AMD’s PowerTune technology.
Specification:-
- Core Clock Speed: 900MHz (925MHz Boost)
- Stream Processors: 1024
- Frame Buffer / Memory: 2GB GDDR5
- Memory Width / Speed: 256 bit / 5600MHz
- Power Connectors: 6-pin
- Display Outputs: 2x DVI + 1x HDMI + 1x DisplayPort
- Power: 115W TDP
- Dimensions: 228(L)X109(W)X35(H) mm Size / 2-Slot Cooler
- 2yr Warranty
Was [£109.99] Inc. VAT
Only £79.99 inc VAT - ONLY 50 UNITS AVAILABLE!!
ORDER NOW
Samsung U28D590 28" 4K 60Hz 1ms Gaming Widescreen LED Monitor - Black **OcUK Exclusive** @ £499.99 inc VAT
OcUK will be the first in the UK to get official UK version of this monitor by upto nearly a month. We are expecting our delivery the last week of May. None of our competitors will get stock until mid-end of June as we have an exclusive arrangement with Samsung. This monitor is one of the best 4k displays available and OcUK will have it before any competitor by upto at least two weeks. Pre-order with confidence from ourselves on this stunning Samsung U28D590 28" 4k 60Hz 1ms Gaming Widescreen LED Monitor.
Samsung U28D590 the Main feature of novelty is the resolution 4K (3840×2160), exceeding Full HD (1920×1080) four times. Natural color reproduction with soft color transitions is achieved, in particular, by playlist 1 billion colors. Response time is 1 MS, which perfectly fit to play the game content. Also amongst the peculiarities of the availability of an updated Picture-in-Picture (PIP 2.0). With its help it is possible to reproduce a picture of a small window in the original resolution up to Full HD (1920×1080 pixels) as the main picture is reproduced in UHD. In addition, when playing content small-resolution, innovative function UHD upscale will improve the clarity and quality of the image to the maximum possible resolution of 4K (3840×2160).
The novelty provides connectivity, audio-video devices: include 2 HDMI port and one interface connector Display Port. It is worth noting that the monitor can be connected at once two PC and play back content from both devices without any loss of quality, resolution images with each PC will 1920×2160. This monitor can be easily connected Xbox or PlayStation 4 via the HDMI.
Specification:
- Size with stand (W x H x D ) : 660.9x486.3x169.4 (mm)
- Without stand (W x H x D ): 660.9x410.0x64.7 (mm)
- Packaging (W x H x D ): 794x452x109 (mm)
- Display Screen Size: 28" (70.8cm)
- Aspect ratio: 16:9
- Panel Type: TN
- Brightness: 300cd/m2
- Contrast Ratio: 1000:1 (Typ)
- Dynamic Contrast Ratio: 10,000,000
- Resolution: 3840x2160 (Only over DisplayPort at 60Hz)
- Response Time: 1ms (GTG)
- Color Support : 1B
- Viewing Angle (H / V ): 170 ° / 160 °
- Connectivity: 2x HDMI (30Hz), 1x DisplayPort (60Hz)
- USB Hub: NO
- Speakers: NO
- Warranty: 2yr
Only £499.99 inc VAT - BUY A SAPPHIRE CARD ON THE DAY TO BE ENTERED INTO A RAFFLE TO WIN THIS, DRAWN AT 4PM THAT SATURDAY!!!
ORDER NOW
So insanely crazy deals, we shall have even more deals on the day on memory, SSD's, periphals and loads of cool stuff going on, see the thread about the AMD Event as a reply to this post for info on more cool stuff.
Remember these are first come first served deals and the doors open at 9am, I repeat the doors open at 9am, of course there is nothing to stop you from getting here at 6am and queuing outside the door.
Hi there
Specification:-
- GPU: 2x Hawaii XT
- ROPS: 128
- Warranty: 2yr
ORDER NOW
Specification:-
- Radeon R9 290
- GPU: Hawaii Pro
- Warranty: 2yr
ORDER NOW
Specification:-
- Power: 250W TDP
- 3yr Warranty
ORDER NOW
ORDER NOW
Specification:-
- Power: 115W TDP
- 2yr Warranty
ORDER NOW
Specification:
- Panel Type: TN
- USB Hub: NO
- Speakers: NO
- Warranty: 2yr
ORDER NOW
