OK these are the pics I took ...sorry if they are not too clear
This first one is of some small rubber dampers I've had for a while ...these are what I used to put under the fan screws
)Mike in the top picture are the things I used......they came with some fans I got some time ago ...some 120mm eLoops
but have to say they alone didnt solve the vibration issue
these are the fans , see the little rubber dampers 8 of them.
http://www.overclockers.co.uk/showproduct.php?prodid=FG-057-NB&groupid=701&catid=2331&subcat=4
Dear All,
We have a very low rate of faults with our graphics boards. That an issue showed up and someone was able to fix it and subsequently did a video shows a real enthusiasm for our products. However this issue only occurred on a very small number of early production boards and has been addressed. The rattle is caused by a resonance in the shroud, only at certain fan speeds, and it vibrating against the fins of the cooler. The clearance has been adjusted and this no longer happens.
We would normally recommend users with any issue to take advantage of our warranty return and repair service. However, the fix in the youtube video will not invalidate the warranty because it only involves removing the fan from the cooler - not the cooler from the board, therefore not breaking the critical thermal bond between the cooler and the gpu or other components.
Best Regards,
SAPPHIRE Technology
Dear All,
Best Regards,
SAPPHIRE Technology
Dear All,
Best Regards,
SAPPHIRE Technology
and its really noisy!
Dear All,
Best Regards,
SAPPHIRE Technology
Reviving an old thread!
Interesting that my old 290 TRI-X OC does not rattle at all but the new one which I purchased from OCUK 1st week of November doesand its really noisy!
Going to attempt the fix, if that doesn't work its coming back to OCUK/Sapphire for a replacement!
