- 25 Mar 2004
- Fareham
I guess i was correct about PTR then...
Indeed, you get a cookie
Best changes so far:
New stash tab
FOTH no longer makes the screen shake...
XP in Greater Rifts is nuts. I literally went from 566-568 in 4-5 greater rifts, probably 1-1.5 hours played time as the first greater rifts you enter go quickly.
I got to lvl 29 before I ran out of time. Had 99% progress bar when my 15 mins was up. I was on level 7 of the rift though so not a great one for density.
Goblins had 800M health at lvl 29 (pretty sure T6 has around 300M-400M tops). lvl 25 felt like current T6 is now more or less for difficulty, seems to ramp up quite quickly after that (need to do some more testing later on).
You can't swap items from inventory during greater rifts so no more nemesis bracers or swapping furnace at RG. There are also precious few clickables so Harrington belt will no longer be the best belt to use in Greater Rifts anyway. I will see how my mileage goes with my Witching Hour instead.
PTR reports say that Vigilante Belt now rolls CDR so that might well BiS belt for that reason alone for classes like Crusader which rely on CDR and AC uptime.
*Side note: left the clan as it just didn`t have the same "feel" to me as the OS one...nothing against the people in it at all,maybe i had an off day*
Vigilante belt does roll with CDR, just had one drop.
This is my first time participating in a PTR am i right in thinking you don't get to keep anything you find?
That's a shame
From what i've experienced, people are very friendly and often, when I've needed helped with bosses (can't solo Belial, Urzael or Maltheal at T2) people will join just to help out and leave. Or, if you're wanting group action (oo err) there's lots of Rift groups every night.
3) Further to the above, the greater rift token doesnt appear to be character bound so there is nothing to stop you doing some levels of the rift on one character and then switching to another for later levels. In fact this is what I intend to do with my current level 24 token, as I'm pretty sure my sader wont finish it but there is a chance my DH will. This could be a good way to split gear farming across your chars. Use the lesser geared characters for early tiers and then use your better geared ones later on.
