Unigine Heaven 4 benchmark
Since my CPU will give me crashes and BSOD's at even 4.0GHz (multiplier 40, auto voltage (sets it to 1.312) 1600mhz cl8-8-8-24 1t) I've given up OC'ing the CPU and instead OC'ed my two MSI GTX 780 reference cooler to match the EVGA GTX 780 SuperClocked reference cooled card too.
GPU 780 @941/1502, CPU 3930k @3.8, Gripen90
1080P
1440P
1080P
Could you redo your 1080p run with a score over the cobble stones please for the scoreboard.:)
Hello new here :D
Figured I would post my best 290p score so far.
4770k @ 4.4ghz
Sapphire 290 Vapor x at 1200 / 1700
We aim to please.:)
4 x 290Xs @1230/1500
4930k @4.8
4K
Awesome score. I bet Unigine looks great in 4k :D
Also looks like I'm currently the highest for a 290p, look at me!
Hey Kaap what are your stable gaming clocks on your cards? 4 way and single if you don't mind.
Looks like I'm 24/7 stable at 1170 / 1625.
I always use stock clocks for gaming but stable would be 1200/1500 on all 4 or 1200/1625 on a single for most things. As I say for gaming I don't use those clocks because of the amount of heat produced and the elec used. Even using water you have got to get rid of the heat.:D
I'm jealous! My 290 stays cold enough. Highest I seen it get to was 73c with voltage offset maxed.
Even with maxed voltage offset it refuses to run at 1200 completely stable :(
Fast card, just wished it had a little more potential like the 780s do.
