If you want 2560x1440 @ 144Hz @1ms
That's exactly what I'm after. Already have a 780ti. Just thinking ahead :/
Then the SWIFT is for you my friend.
Will wait a bit. Not paying the premium.
Asus have managed to get us a lot more stock, so no need to for two separate SKU's now, but stock will still be very tight so the early adopter price is still a bit higher than usual.
Once stock is free flowing we should be able to do deals on them around the £659.99 Inc. VAT mark.![]()
Noticed a lot of people going for this are only running single cards, whats the point going 120-144hz monitor if you're running sub 60fps on maxed out modern titles at 1440p? Yes gsync will help but the real benefit of high hz is when it coincides with high fps.
Most people dont run max settings on next gen titles.
windows is better @ 120hz and eventually we will get better GPUS so 120fps @ 1440p will be viable....
What's the point getting a decent monitor and making the image look terrible through low settings or no AA![]()
Don't really need a lot of AA for 1440p
I've heard this is nonsense, I'm sure Gregster even said with 4k he uses 2xAA still.
Erm what? Just because you play BF4 at low settings for competitiveness doesn't mean everyone else does.
Same can be said for 4k eventually...
Don't really need a lot of AA for 1440p, 2xmsaa at most maybe. Plus Asus have said themselves that 120hz 4k is long way off.
It's true though, people don't run max settings on next gen games because by definition any games out are current generation, and you can't run games that aren't actually out.
It's not about resolution, it's about pixel density. 1080p on a phone doesn't need 8x AA to look smooth
Regardless, preorderedBeing waiting all year for this sucker!
I meant 12k on current sized monitors.... I thought that was quite obvious.
Anyways enjoy your preorder I'll probably be joining you shortly after unless something similar is announced.
