many tips in this thread:
russian planes are OP so best to use them as a second faction in combo with the brits.
use eagles on advanced training of crews only anything else would be a waste.
use specific crews for specific types of planes, e.g. 2 bomber crews on which you upgrade the gunners, etc whereas on the other crews you upgrade the pilot, etc.
best to try and get the most out of your game time than chase targets for hours, e.g. your in a game for a certain amount of time, best to go for easy targets and kill them quick and move on rather than climb up and chase a bomber for 10+ minutes. in the 15 minutes it took you to take out that one bomber I could have taken out 10+ easier targets meaning I get a much higher score/RP, etc.
most of it is using your initiative and skill tbh, never take on a powerful plane head on, pre fire at weak/same level head on opponents aiming slightly above them to account for bullet drop. best to avoid head on confrontations though, if someone is coming head on to you try and veer off to the side and turn onto their back if you can.
the best bullets are stealth or the most expensive ones usually whichever they may be.
tracers just give your position away.
I usually just head for the nearest red dot whether it be plane or truck.
How do you use the Russians as another faction? I'll switch to stealth bullets once I'm used to shotting patterns.
Eh up gents, PC war thunder player here!
Any time you guys fancy a friendly sqn battle give us a shout and we'll sort something oout, we can match any tier, 4v4 8v8 whatever you fancy!
I am seeing a lot of user comments on Metacritic saying that this game is getting increasingly worse with each patch and people recommending against getting into it... are they just numpties who don't know what they're talking about? Is it still worth getting into?
Going to buy a PS4 this week and will be hitting the F2P games first.![]()
I downloaded and had a play tonight... I really liked it from what I saw (all tutorials and a few random MP games), even if I did epically suck!
Richdog_OCUK is my username... add me please and lets set up some games or something.![]()
People on most nights.I'm very much inactive tbh, not played it in months. Probably due to nobody else joining in.
I would love to play on PC but my new pc has a lot of issues. First PC I have built which has ever done this. Output to the screen randomly cuts off and never comes back on. Cannot even restart the PC need to power off then power on.
I also have freezing issues with CS which never happened on any older pc.
I also need to take it apart one day and replace 2 sata cables as they have degraded over time.
