It must very from game to game, every time I have seen it thus far (Diablo 3, Guildwars 2, Wildstar, etc) it just makes the game look like it's running the Nintendo 64 full screen blur filter, looks better without it.
Strange thing to say considering FXAA is known for being too blurry.
There was a comparison posted here a while ago between FXAA, SSAA and MSAA and although the sample size was only 1 or 2 games, it looked pretty convincing.
<snip>
Power consumpsion is higher than at lower resolutions as the CPU does not hold the GPUs back. My Titans have never had a problem with a EVGA1500 watt PSU (it can handle peaks of 1650 watts). When I benched Sky Diver @4K the Titans demolished the PSU very easily.
<snip>
Where the GPUs work harder they produce more heat.
<snip>
No but now I have a 4K screen I wish mine were 8gb cards.
For one or two cards 4gb is ok but with three or four cards you can really push the settings but then find a lot of stuff using all the VRAM.
Which games are you using more than 4Gb in, using DX?
If you get the chance, is there any possibility of seeing if PCI-E generation has a higher impact with the higher resolution? I know PCI-E 2 to 3 has a limited impact at 1080P (less than 5% from memory?) but wondering if that increases with 4K. To be honest, I just want to know how much my 2600K is holding back my two 290s at 3K as to whether it's worth the money to upgrade to Ivybridge/Haswell - I'm hoping not as I haven't got the money to spend!![]()
Crysis 3 I get good fps on the 290Xs but also big drops every few seconds when I hit the memory buffer.
Hitman when it exits the bench, I have to wait about 15 seconds or so when the PC is exiting the bench and the fps drop by about 20fps while everything is frozen and doing nothing.
Mantle is the real nightmare with minimums of less than 3fps on the Thief bench.
When I am next off work I will do more benching and testing.
It is not really the answer for anyone to suggest that we can reduce the settings to get things running as this defeats the point of 4K and I may as well get my 1gb HD 5970s out to run at the resolution.
I think it is important if people can posts their experiences of using 4K (including the bad bits) so anyone considering the resolution can make an informed decision as to whether it is for them or not.
Cheers Kaap and at least you have the Titans if you want to enter the bench threads for 4K![]()
Old guard to the rescue![]()
So you're telling me at 4k you can tell the difference between x8AA and x2AA? I've no doubt that 4gb is not enough for every title at the absolutely highest settings, mantle aside. But i bet it is enough for X2-x4AA in most titles and if not FXAA in others. I bet the difference in image quality is unnoticeable at such a high resolution. You yourself just said you can hardly see a difference between 1600P and 4K, except in Civ.
The question is can you use it or not, it is as simple as that.![]()
Yes
Going from 1600 to 4K there is a big difference in image quality using the same settings.
Screen shots can't do it justice
Screenshots please.![]()
