CS:GO Discussion
Ugh. They look like CoD maps :(
I used to like the CS maps because they are linear. Look at Dust 2. Probably the best CS map. You only have two ways to B and three to A (Tunnel, Mid; Long, Short, Mid). Also, when you are attacking and you are looking at the site, you basically know where they are. In these maps, you have to look around 180deg and then look at the top raft thingies.
Yeah they all feel like cod maps too apart from overgrown that's a lot more simple in comparison I really like it, the others are just for your typical run and gunner re spawn shooters
Tried insertion on MM.
It provides a new spawning system (the CTs spawn depending where they step in the first few seconds) but apart from that it is TERRIBLE! It is hostage rescue though :p
I have had this problem since the BETA. If anyone knows the fix, please let me know. :)
http://forums.steampowered.com/forums/showthread.php?t=3249313
I get that at times (same with casual). I just leave and retry a few more times and it works.
You can join casual games and arms race game either from friends list or even from the ocuk group.
The new maps are more arms race type then comp but I still like them mostly.
This map actually has flow.
overgrowth is probably the most viable mm play of the lot and its what mm keeps giving me. Theres 3 paths between sites but I like the oilrig best, mist is the most headache inducing :o
D93A16483B404EB591B764879A61156FE34D361F
Had a game we lost 9 rounds to start but we won 13 as T for the game win anyway, maybe its biased or that our opponent was a full clan gave them a headstart
most overplayed also, not a fan of how the games just repeat the same thing.
I bought the coin and won the case after luckily so its mostly paid for itself, this must be the best dlc setup in the industry
insertion reminds me of arma or bf2 map
About 1.25 and 500 dpi.
Yes, very low sense.
http://ragial.com/mouse/
This calc shows Im .001" per pixel on the mousepad. Seems to work so far, not sure if I will stick but I copied some radical settings from a GE off twitch. He said the 6/11 thing is not absolute but 3/11 is used by some also and Im 2 sens with 1800 dpi, I got nothing to lose trying it
The tek9 was a mini AK for a while :p fixed not long after and missions work out ok now
Dust 2 isn't overplayed, its played a lot because its easily the best map in CS to most people.
The exact same things never happens in a game like this.
and Valve are still laughing to the bank after you paying for the DLC and getting 15% of the case market sale. You feel happy that you get your DLC paid for.
Everyone wins.
Everyone wins.
Valve are the winners always. I am not the loser though. The guy who bought my case and got a 3p skin is the loser :p
EDIT: FYI, they removed the AWP blur. So now you can put shaders up and have nice guns!
So i've played a couple of the new maps in DM mode, really not impressed. What do you guys think of them? I doubt anyone will play these in Competitive, maybe to get the achievement but that's it.
Reckon this might be due to the inability to find a server with low ping. Might be worth trying with increased allowable ping. Has worked for me but cant say with certainty (ie. i tried with 100ms instead of 50ms), if that is definitely the solution.
I had a similar problem. I verified integrity of game files and it seemed to fix the problem.
5UB, you're not using an older Virgin superhub or similar are you? I used to have real trouble with the earlier ones as their low RAM made pinging a ton of servers flood the routing table and I'd be left with zero responses as the router had a fit. More modern ones have better sized tables afaik but I moved to using a dedicated router and moving the Superhub into modem move.
I tried Castle & Black Gold yesterday, Black Gold is god awful, my instant thought was very much CoD 4+ style maps. CoD 1 & 2 maps were quite linear I thought and that's why it was such a popular game in its time.
I wish developers would see that simple maps are better when it comes to competitive game play.
