I'm going to be putting cash towards it as well.
Technically that's in violation of the terms of the scheme, so it'll depend very much on how much the relevant bike retailer is prepared to bend (and by bend I mean break) the rules for you.
Has anyone I here got a ribble or owned one. I'm still a little unsure whther to for the ribble or not. One mate who's been cycling for years has one and loves them and has has had several over the years recommends them but another who is a cycle mechanic and works in local bike shop doesn't like the and seems the carbon frames are not very good.
Thanks
Thanks gribs. When you say not setup properly what do you mean? Have you had any issues at all or just build quality type stuff.
I suspect more than likely I will end up going with ultegra just like the feel of the campag hoods and the general look of the shifters but bang for buck I'd imagine the ultegra are better for what I need.
What's the ride position like on the r872 in comparison to the evo2
It was just the gears weren't set up properly. On my Evo the indexing was miles off and the limit screws hadn't even been set. It wasn't really a problem as I could do it myself but I'd not expect to have to. A canyon mtb I'd got just before it was perfect for example.
The position on the R872 is almost identical to my Evo but strangely the r872 is a large and the Evo a medium. They do feel quite different to ride though and the r872 is noticeably stiffer but I've not found it any less comfy.
Thanks so nothing major really. No issues with frame? I really like the look of the r872 and aren't to concerned over it being stiffer just wanted not vastly reduced comfort over the gran fondo. Ribble say I'm a size 50 on 872 and 52 on gf.
