No matter what any reviewer says I only care what my eyes say to me when its is in front of me, not happy it goes back.
Could be teething problems with the first version of G-Sync and/or the display drivers.
Also I could have sworn I heard somewhere that to use G-Sync you have to set you refresh rate to 120Hz rather than 144Hz as it doesn't work at 144.
I think gsync works at 144hz, it's the ULMB mode which only works at 120hz if I recall correctly. You can't notice the difference between 120/144hz anyway, at least I can't on my BenQ 144hz panel.
Most of the reports I've seen from 144hz users is that its really difficult to tell the difference between 120 and 144 so the limitation if valid doesn't bother me.
For those of us that have killer PC's and want the ultimate experience, ULMB strobing at 120+ FPS/Hz will be much better than non-strobing sample-and-hold G-Sync.
ULBM works at 85hz, 100 and 120Hz settings according to the manual although I've not had chance to test that yet
would be awesome if you posted color accuracy comparisons, specifically to U2713HM, FV2736WFS and BL3200PT if you can.
that's pretty much my only reservation about this screen, i'm afraid the colors will be complete crap...last TN panel i have tested was the VG278 and colors on that the a complete mess compared to a dell IPS. hope this turns out better.
It isn't really colour accuracy that will concern people but rather how rich colours look. I take issue with the notion of 'colour accuracy' in this sense.
I'm sure you're aware of this, but for those who aren't - readings from a colorimeter at the centre of the screen for colour accuracy are of little use when colours are not consistent throughout the screen. The colour accuracy may be very good in the centre of the screen, but the same shade will be represented differently on a TN panel below and above this in particular.
I am hoping that the SWIFT will give rich and reasonably well represented shades on the whole. Anything more is asking too much.
