Hi,
I bought a new Crucial m500 off a well known auction site and have been having problems with it recently. When it works it works great but every so often - it could be 5 minutes or after 5 hours - it will just entirely freeze up my system. There is no BSOD, it just locks up. If I am doing anything with sound the sound will get stuck in a loop. I then have to hold the power button to turn the computer off.
I did a clean install on the SSD and kept my old OS install on my old hard drive which is what I am on now. I have ruled any other variable out other than the SSD because the computer works faultlessly when on my old HD.
I have upgraded the firmware to MU05 (was on MU03 when I got it). I can't remember whether the problem was present before I upgraded the firmware or not as I did it fairly soon after receiving it. Should I try a firmware downgrade to see if that fixes the problem? Problem with that is I can't seem to find any download links for the old firmware which still works.
Any other ideas? I have tried reinstalling the OS but that did nothing. It's a really annoying problem and I want to verify that the SSD is unfixable before buying a new one.
Thanks
Thanks
