Hi all,
Please note, I am not removing the original tubes, instead I'm looking at covering them with some blue tubing to match my system
Have a look at this video:
Question is though, does anyone know the size tubing I'd need to do that for the H100i? As his model doesn't seem to be the H100i
Also having never had a watercooled PC before, the measurement he gives of "12,7/9,65mm - 3/8" (10mm)" means nothing to me
Can someone break it down and explain it maybe? Thanks!
Hope someone can help
EDIT: Someone in the comments has used "1/2in. ID X 3/4in" on a H100i, guessing the ID is internal diamater?
Anyone here done a similar mod?
Can someone break it down and explain it maybe? Thanks!Hope someone can help
