Modding a Corsair H100i tube colour
11 Oct 2011
UK
Hi all,
Please note, I am not removing the original tubes, instead I'm looking at covering them with some blue tubing to match my system
Have a look at this video:
Question is though, does anyone know the size tubing I'd need to do that for the H100i? As his model doesn't seem to be the H100i
Also having never had a watercooled PC before, the measurement he gives of "12,7/9,65mm - 3/8" (10mm)" means nothing to me :D Can someone break it down and explain it maybe? Thanks!
Hope someone can help :)
EDIT: Someone in the comments has used "1/2in. ID X 3/4in" on a H100i, guessing the ID is internal diamater?
Anyone here done a similar mod?
I know but why would you cover up the tubeing sounds pointless just get a custom loop
Because I didn't want to have my first loop as a custom loop, didn't have the money to spend at the time
So for now I just wanted to make this one match the rest of the colour scheme in the pc
I guess you could paint them blue with Plastidip?
I'm not sure if that's feasible or not, but I would just go for a custom loop of you want to change the tubing.
Yeah that's why I linked to the coil as well as that could help hold it all together ;)
Aha that was the reason, I'll see if it works like this, if not I'll have to get the coil. I prefer the look without so I'll try get it working without first
in the video he then re-made them with the cut in along a different side so it didn't bump.
Yeah I saw that but was just confused by his explanation haha, I'll have to have a look and cut the pipes on the 'seam /join' if there is one
