- 27 Oct 2013
- Sheffield
One question not mentioned anywhere, does g-sync still work in 3D vision mode?
Don't think so mate. I wanna hear some reviews on the 3d 1440p @ 60hz
I would run ulmb in desktop tbh and switch to g-sync for gaming regardless of what frames I was able to push, it's gotta always be a better experience with synced frames right?
You wouldn't want to run ULMB in desktop as it introduces a noticeable flicker in static images. Okay useful for gaming where you want to remove perceived motion blur, and aren't using g-sync
I thought ulmb was like the light boost hack but built in?
I didn't have flickering on my benq when I ran it...
Agreed.. Maybe a bit too complicatedGreat review Si and very very detailed![]()
Been informed by what I consider a reasonably reliable source that they now won't be shipped anywhere in Europe until 1st week of August at the earliest. He said definitively that they won't make July.
Would it be a waste of money if i were to buy this monitor to use with Crossfire 290x's?. Ive been waiting for a 1440p 120hz+ monitor since i built my pc late last year, wanted to stay away from the Korean monitors but my patience is running thin and this monitor could be the answer. Or would i be simply overpaying for technology which i cant use? thanks.
Objective data is way more useful than cursory subjective data (especially in regard to the mechanical way your eyes view motion). Pull this link up on your display at 144 Hz and then in 120Hz 10% Lightboost mode and I guarantee you will see a huge difference (you must have a high FPS compatible web browser):
http://testufo.com/#test=photo&photo=eiffel.jpg&pps=1440&pursuit=0&height=0
Didnt I read on these forums that Asus was going to announce this very monitor but without gsync, fairly soon ?
UPDATED FAQ!!
Really informative so check it out, about 3d usage, Lightboost bla bla, you get it
http://rog.asus.com/339252014/gaming-monitors/faq-rog-swift-pg278q-27-inch-g-sync-gaming-monitor/
