# Logging settings
set logGroup           "ConfigurationManager"
set logLevelWarning    warning
set logLevelInfo       info
set logLevelDebug      debug
log $logGroup $logLevelInfo "Parsing configuration script"
# Constants
seti Off 0
seti On  1
seti Low    3
seti Medium 3
seti High   3
seti MediumButDefaultLow 4
seti memoryLevelHigh    512
seti memoryLevelMedium  384
seti memoryLevelLow     256
seti memoryLevelUnknown 0
if ( match("${osVersion}","*NT 6.0*") )
    seti cpuLevelHigh        3000
    seti cpuLevelMedium      2600
    seti cpuLevelLow         2000
    log $logGroup $logLevelInfo "Setting cpu level for Vista."
else
    seti cpuLevelHigh        2800
    seti cpuLevelMedium      2200
    seti cpuLevelLow         1450
    log $logGroup $logLevelInfo "Setting cpu level for non-Vista."
endif
seti cpuLevelUnsupported 0
# Identify gfx device
# set some config variables based on a card table and vendor specific rules
# sets isCardFound, cardVendor, and cardName
include "Video Cards.sgr"
# Fallback on the card name text supplied by the card itself.
# Assumes that at least the cardVendor has been matched, since
# vendor name is not contained in some vendor card names.
# Note that specific vendors are overridden to a default card.
#  For ATI    -> Radeon 9800 Pro
#  For NVIDIA -> NVIDIA 4800 TI SE
if (not $isCardFound)
   set cardName $cardNameText
endif
# Configuration override controlled by command line option -cardConfig.
if (varExists(cardConfig))
   # test unsupported cards using sw rendering
   if ($cardConfig = 1)
      log $logGroup $logLevelInfo "Testing with all devices unsupported."
      set  cardVendor    TestingAllUnsupported
      set  cardName      TestingAllUnsupported
   elseif (($cardConfig = 2) and ($deviceNumber = 0))
      log $logGroup $logLevelInfo "Testing with the first device unsupported."
      set  cardVendor    TestingFirstUnsupported
      set  cardName      TestingFirstUnsupported
   elseif (($cardConfig = 3) and ($deviceNumber != 0))
      log $logGroup $logLevelInfo "Testing with the all devices except first unsupported."
      set  cardVendor    TestingAllButFirstUnsupported
      set  cardName      TestingAllButFirstUnsupported
   elseif (($cardConfig = 100) and ($deviceNumber = 0))
      log $logGroup $logLevelInfo "Testing first device as swvp only part."
      boolProp forceSoftwareVP true
   endif
endif
# Determine if gfx device is supported, force software rendering if not
setb useSoftwareRasterizer false
if (match("${cardVendor}", "ATI"))
   if (match("${cardName}", "*Mach*") or match("${cardName}", "*Rage*"))
      setb useSoftwareRasterizer true
   endif
elseif (match("${cardVendor}", "NVidia"))
   if (match("${cardName}", "NV 1") or match("${cardName}", "NV 2") or match("${cardName}", "*Riva*") or match("${cardName}", "*TNT*"))
   endif
elseif (match("${cardVendor}", "Intel"))
   if (match("${cardName}", "*810*") or match("${cardName}", "*815*") or match("${cardName}", "*740*") or match("${cardName}", "*752*"))
   endif
elseif (match("${cardVendor}", "S3"))
   if (not match("${cardName}", "*GammaChrome*") and not match("${cardName}", "*DeltaChrome*"))
   endif
else
   # unsupported/unknown vendor
endif
if ($useSoftwareRasterizer)
   log $logGroup $logLevelWarning "Unsupported video card.  Forcing software rendering on this device"
else
   log $logGroup $logLevelInfo "Supported video card."
endif
if (not $useSoftwareRasterizer)
   # failed to obtain device texture memory size, force to 32MB
   if ($textureMemory = 0)
      seti textureMemory   1744
      setb textureMemorySizeOK false
   endif
   if ($textureMemory < 28)
      log $logGroup $logLevelWarning "Insufficient video memory.  Forcing software rendering on this device"
      # require a card with at least 32MB
   endif
endif
   # ignore texture memory reported by gfx device, this is not hardware texture memory
   seti textureMemory 32
endif
   log $logGroup $logLevelInfo "Hardware rendering is enabled"
endif
# Apply gfx device specific workarounds
# Available device props:
#  forceSoftwareVP
#  forceSoftwareDevice
#  queriesOK
#  windowedModeFormatConversionOK
#  enumerateMultisampleLevels
#  skipValidateDevice
#  enableDriverMemoryManager
#  softwareDeviceLocalVideoMemorySize
#  deviceLocalVideoMemorySizeDefault
#  disableVSyncSupport
#  substituteFlipForDiscardSwapEffect
#  minTextureDimensionForBalance
# Additional props:
#  vs2LoopsFunctional
setb textureMemorySizeOK        true
setb supportsDirtyRect          true
setb supportsTurboRect          true
setb supportsSpecialEventCamera true
setb forceLowSettings           false
setb forceLowResolution         false
setb defaultLowResolution         false
setb forceMediumMaterialDetail  false
setb isIntegratedChipset	      false
setb forceMediumShadows          false
setb forceMediumObjectDetail     false
boolProp useRenderTextures       false
uintProp antialiasingSupport             1
boolProp dontMergeNHFlora	true
   # never trust the driver to manage its own memory
   boolProp enableDriverMemoryManager  false
   boolProp vs2LoopsFunctional         false
   boolProp presentWorkaround          false
   boolProp enumerateMultisampleLevels true
   # not enough texture memory for antialiasing
   if ($textureMemory < 127)
      boolProp enumerateMultisampleLevels false
   endif
   if (match("${cardVendor}", "NVIDIA"))
      # on NVidia cards, create a dummy texture on device creation to prevent BSODs
      boolProp createNVidiaWorkaroundTexture true
      if ($appControlledAA)
         # nvidia drivers handle offscreen aa
         uintProp antialiasingSupport    3
      else
         # remove this when the texture manager balancing is fixed.
         boolProp disableTexMemEstimateAdjustment true
         # turn off dirty rects
         setb supportsDirtyRect          false
      endif
      if (match("${cardName}", "*GeForce2*Integrated*") or match("${cardName}", "*GeForce?2*Integrated*") or match("${cardName}", "*GeForce4*Integrated*") or match("${cardName}", "*GeForce?4*Integrated*") or match("${cardName}", "*GeForce2 Quadro2 Pro*"))
         boolProp causticsEnabled            false
         setb forceLowSettings   true
         setb forceLowResolution true
      endif
      # the 6200 Turbo Cache peformed very poorly in CATLAB runs for EP2
      if (match("${cardName}", "*6200 TC*") or match("${cardName}", "*6100*"))
         setb defaultLowResolution true
      endif
      # need to get around the problem of z fighting in GeForce4 cards
      if (match("${cardName}", "*GeForce4*"))
         boolProp raiseLightSnowFF true
      endif
      # disable shaders by default for NV3x generation, only enable for high end cards
      if ($maxVertexProgramVersionHWMajor = 2)
         boolProp useShaders false
         if (match("${cardName}", "GeForceFX*") or match("${cardName}", "*GeForce?FX*"))
            if (match("${cardName}", "*57?0*") or match("${cardName}", "*58?0*") or match("${cardName}", "*59?0*"))
               boolProp useShaders true
               log $logGroup $logLevelInfo "Enabling shaders for high-end NV3x"
            endif
            if (match("${cardName}", "*NV35*") or match("${cardName}", "*NV36*") or match("${cardName}", "*NV38*") or match("${cardName}", "*NV39*"))
            endif
            # 5700 cards sometimes have problems with bump mapping so setting default to medium
            if (match("${cardName}", "*5700*"))
               log $logGroup $logLevelInfo "Forcing Medium Material detail on 5700"
               setb forceMediumMaterialDetail true
            endif
            if (match("${cardName}", "*5700LE*"))
               log $logGroup $logLevelInfo "Forcing low settings on 5700LE and 6100"
            endif
         endif
         if (match("${cardName}", "QuadroFX*") or match("${cardName}", "*Quadro?FX*"))
            if (match("${cardName}", "*3000*") or match("${cardName}", "*1?00*"))
               log $logGroup $logLevelInfo "Enabling shaders for high-end NV3x Quadro"
            endif
            if (match("${cardName}", "*2000*") or match("${cardName}", "*1000*") or match("${cardName}", "*1300*"))
               log $logGroup $logLevelInfo "Disabling caustics as these cause cards cause problems with shadows"
            endif
         endif
         # caps read vs 3.0, but dx9b is returning vs 2.0, once 9c is used this fix can be removed
         if (match("${cardName}", "*GeForce*"))
            if (match("${cardName}", "*68?0*"))
               log $logGroup $logLevelInfo "Enabling shaders for high-end NV40 Parts on Dx9b"
            endif
         endif
      endif
      if ($maxVertexProgramVersionHWMajor = 0)
         boolProp skipValidateDevice true
         log $logGroup $logLevelInfo "Enabling D3DERR_CONFLICTINGRENDERSTATE validation workaround"
      endif
   elseif (match("${cardVendor}", "ATI"))
      # loops support broken in 6458. Fixed in catalyst 4.9 (6476) but we require 4.10 to be safe.
      if ($driverBuild >= 6476)
         boolProp vs2LoopsFunctional true
      endif
      # workaround for forced aa crash as of 6458.  Fixed in catalyst 4.9 (6476) but we require 4.10 to be safe.
      # TODO: this is not yet enabled, pending testing
      #if ($driverBuild < 6476)
         boolProp useRenderTextures true
      #endif
      # avoid a race condition with color copies and ui
      boolProp presentWorkaround  true
      if (match("${cardName}", "*Radeon?VE*") or match("${cardName}", "*7?00*") or match("${cardName}", "*R100*") or match("${cardName}", "*IGP 3?0*") or match("${cardName}", "*9100 IGP*"))
         log $logGroup $logLevelInfo "Forcing turbo rects off"
         setb supportsTurboRect   false
         boolProp simpleTerrain              true
         if (match("${cardName}", "*9100 IGP*"))
            log $logGroup $logLevelInfo "Forcing low resolution"
         endif
         if (match("${cardName}", "*Radeon?VE*") or $driverBuild < 6414)
            log $logGroup $logLevelInfo "Forcing swvp"
         endif
      endif
      if (match("${cardName}", "*X1300*") or match("${cardName}", "*X300*") or match("${cardName}", "*XPRESS 200*"))
         log $logGroup $logLevelInfo "Forcing medium settings or lower"
      endif
      boolProp usePS30 false
      if ($maxVertexProgramVersionHWMajor < 2)
         # Radeon 8500 and greater have problems switching between FF and VS?
         log $logGroup $logLevelInfo "Forcing shaders of for ATI DX8"
      endif
      if (match("${cardName}", "*8500*"))
         #avoid z fighting with light snow
      endif
      if (match("${cardName}", "*9600 SE *"))
         setb forceMediumShadows         true
         setb forceMediumObjectDetail    true
      endif
      if (match("${cardName}", "*Mobility*"))
         setb isIntegratedChipset true
      endif
      # X800 based cards exhibit rendering corruption if turbo rect is enabled
      if (match("${cardName}", "*X800*") or match("${cardName}", "*R420*"))
      endif
      if (match("${cardName}", "*92?0*"))
         log $logGroup $logLevelInfo "Forcing shadow detail on 9250 and 9200"
      endif
      if (match("${cardName}", "*GammaChrome*") or match("${osVersion}","*NT 6.0*") )
         log $logGroup $logLevelInfo "Forcing Gamma Chrome to use fixed function shaders"
      endif
      # EP6 CATlab reports gray screen during all cinematics
      if (match("${cardName}", "*S27*"))
         setOption SpecialEventCamera $Off
      endif
      if (match("${cardName}", "*X3000*"))
         boolProp disableVSyncSupport        true    # work around flickering UI
      else
         boolProp useShaders                 false   # (EP2 change) mostly for performance, but driver issues showed up in v14.14
      endif
      # the Intel minspec driver doesn't misreport available texture memory, so it's not
      # necessary to adjust the texture memory estimate it returns. This may also fix
      # a Windows "device failure" message that occurs sometimes on this device.
      # assuming Intel parts are UMA, drop the texture memory to 32 if not much system memory
      if ($memory <= $memoryLevelLow)
         if ($textureMemory > 32)
         endif
      endif
      if (match("${cardName}", "*845*") or match("${cardName}", "*865*") or match("${cardName}", "*830*") or match("${cardName}", "*855*"))
      endif
      # the 915 sets the caps bit that indicates it can do texture projection,
      # but does it incorrectly in the pixel stage. Here we override the texture
      # projection cap we get from the device.
      if (match("${cardName}", "*915*"))
      	boolProp disableTextureProjection true
      endif
   endif
   intProp deviceLocalVideoMemorySizeDefault ($textureMemory * 1024 * 1024)
else
   # force sw, swvp, and no aa
   boolProp forceSoftwareDevice        true
   intProp softwareDeviceLocalVideoMemorySize ($textureMemory * 1024 * 1024)
endif
# since we don't do bumpmapping on less ps2.0-capable hardware, eliminate tangents
# from the vertex data
# also, the presence of per-vertex tangents in the vertex data stream causes
# "exploded" polygons on the Radeon 9000, even if the data is ignored by the shader
if ($maxPixelProgramVersionMajor < 2)
   boolProp skipTangentsInVertexData true
endif
# Print system info
if ($deviceNumber = 0)
logSystemInfo "=== Application info ==="
logSystemInfo "Name:            ${appName}"
logSystemInfo "Version:         ${version}"
logSystemInfo "Build:           ${buildType}"
logSystemInfo "=== Machine info ==="
logSystemInfo "OS version:      ${osVersion}"
logSystemInfo "CPU:             ${cpuSpeed}Mhz, Name:${CPU}, FPU:${FPU}, MMX:${MMX}"
logSystemInfo "Memory:          ${memory}MB"
logSystemInfo "Free memory:     ${freeMemory}MB"
logSystemInfo "User:            ${userName}"
logSystemInfo "Computer:        ${computerName}"
logSystemInfo "=== Sound device info ==="
logSystemInfo "Name:            ${soundCardName}"
logSystemInfo "Driver:          ${soundDriverName}"
endif
logSystemInfo "=== Graphics device info ==="
logSystemInfo "Number:          ${deviceNumber}"
logSystemInfo "Name (driver):   ${cardNameText}"
if ($isCardFound)
logSystemInfo "Name (database): ${cardName}"
else
logSystemInfo "Name (database): ${cardName} <<NOT FOUND IN DATABASE!>>"
endif
if ($isIntegratedChipset)
logSystemInfo "                 (Integrated Chipset)"
endif
logSystemInfo "Vendor:          ${cardVendor}"
logSystemInfo "Chipset:         ${cardChipset}"
logSystemInfo "Driver:          ${driverName}, Version: ${driverVersion}"
logSystemInfo "Driver version:  ${driverBuild}"
logSystemInfo "Monitor:         ${monitorName}"
logSystemInfo "Monitor aspect:  ${monitorAspect}, ${monitorAspectString}"
logSystemInfo "Screen mode:     ${screenWidth}x${screenHeight}x${screenBPP}BPP,${screenRefresh}Hz"
if ($textureMemorySizeOK)
logSystemInfo "Texture memory:  ${textureMemory}MB"
else
logSystemInfo "Texture memory:  ${textureMemory}MB <<OVERRIDE>>"
endif
logSystemInfo "HW T&L:          Fixed function:${fixedFunctionHWTnL} Programmable:${maxVertexProgramVersionHWMajor}.${maxVertexProgramVersionHWMinor}"
logSystemInfo "Pixel program:   ${maxPixelProgramVersionMajor}.${maxPixelProgramVersionMinor}"
logSystemInfo "Texture stages:  ${textureStages}"
logSystemInfo "AppControlledAA: ${appControlledAA}"
# UI Options
log $logGroup $logLevelDebug "Begin parsing option definitions"
option MaterialDetail
   setting $Low
      boolProp bumpMapping false
      intProp  imageDataSizeReductionOnLoad 2
   setting $Medium
      intProp  imageDataSizeReductionOnLoad 1
   setting $High
      boolProp bumpMapping true
      intProp  imageDataSizeReductionOnLoad 0
end
option ObjectDetail
   setting $Medium
      boolProp reduceBoneWeights true
      boolProp useLODs           true
      intProp  lodOverride       35
   setting $High
      boolProp reduceBoneWeights false
      boolProp useLODs           false
      intProp  lodOverride       0
end
option ObjectHiding
   setting $Off
      intProp renderInsideVisibleObjects 0
   setting $On
      intProp renderInsideVisibleObjects 1
end
option SnowOnGround
   setting $Off
      boolProp showSnowOnGround false
   setting $On
      boolProp showSnowOnGround true
end
option Shadows
   setting $Low
      boolProp simShadows       false
      boolProp objectShadows    false
      boolProp guob             false
      boolProp heightMapShadows false
   setting $Medium
      boolProp guob             true
      boolProp heightMapShadows true
   setting $High
      boolProp simShadows       true
      boolProp objectShadows    true
      boolProp guob             true
end
option OpaqueUI
    setting $Off
       boolProp renderOpaqueUI false
    setting $On
       boolProp renderOpaqueUI true
end
option Reflection
   setting $Off
      boolProp    reflectionWithExtraViewer  false
      boolProp    nhoodWaterReflection       false
   setting $On
      boolProp    reflectionWithExtraViewer  true
      boolProp    nhoodWaterReflection       true
end
option Ceiling
   setting $Off
      boolProp    includeCeilings  false
   setting $On
      boolProp    includeCeilings  true
end
option EffectsQuality
   setting $Low
      boolProp  useEffects            true
      floatProp particleDensity       1
      floatProp particleScale         1
      intProp   maxParticlesTarget    2000
      intProp   particleLODOffset     0    # subtracted from the zoom.
      intProp   effectPriorityLevel   1
      boolProp  enableOceanReflection false
   setting $Medium
      intProp   maxParticlesTarget    5000
      intProp   effectPriorityLevel   2
   setting $High
      intProp   maxParticlesTarget    10000
      intProp   effectPriorityLevel   3
      boolProp  enableOceanReflection true
end
option LightingQuality
   setting $Low
      boolProp lightingEnabled           true
      boolProp portalLighting            false
      boolProp floorAndWallNormalMapping false
      boolProp specHighlights            false
   setting $Medium
      boolProp portalLighting            true
      boolProp specHighlights            true
   setting $High
      boolProp floorAndWallNormalMapping true
end
option SoundQuality
   setting $Low
      intProp AudioPerformance 0
   setting $Medium
      intProp AudioPerformance 1
   setting $High
      intProp AudioPerformance 2
end
# Options without ui access.
option DirtyRect
   setting $High
      # no dirty rects
      intProp dynamicRenderStrategy 0
   setting $Medium
      # 4 buffer mode
      intProp dynamicRenderStrategy 2
   setting $Low
      # 2 buffer mode
      intProp dynamicRenderStrategy 1
end
option FullscreenFadeEffect
   setting $Off
      boolProp enableSnapshot false
   setting $On
      boolProp enableSnapshot true
end
option Turbo
   setting $High
      boolProp useTurboRect true
   setting $Medium
   setting $Low
      boolProp useTurboRect false
end
option SimulatorControls
   setting $High
      intProp maxNumOfVisitingSims   8
   setting $Medium
      intProp maxNumOfVisitingSims   6
   setting $Low
      intProp maxNumOfVisitingSims   2
end
option LightingOptimizations
   setting $High
      boolProp optimizedDiffusion        true
      boolProp incrementalLighting       true
      boolProp lerpLights                true
      boolProp useDirtyTiles             true
end
option AnimationSamplingLevel
   setting $Low
      # sample nearest animation frame
      boolProp animationFrameSampling true
   setting $Medium
      # sample nearest two animation frames and slerp
      boolProp animationFrameSampling false
end
option LivePIP
   setting $Off
      boolProp livePIP        false
      boolProp livePIPDefault false
   setting $On
      boolProp livePIPDefault true
	# do not override user's choice if the setting is ON
end
option SpecialEventCamera
   setting $Off
      boolProp chooseCameraSpecialEventEnabled false
      boolProp CameraSpecialEventEnabled       false
   setting $On
      boolProp chooseCameraSpecialEventEnabled true
end
option ScreenModeResolution
setting $Low
uintProp maxResWidth 1920
uintProp maxResHeight 1080
uintProp defaultResWidth 800
uintProp defaultResHeight 600
setting $MediumButDefaultLow
setting $Medium
uintProp defaultResWidth 1024
uintProp defaultResHeight 768
setting $High
end
option SubjectTracking
   setting $Low
	floatProp centerTrackingDeadZoneMagnitude 70
   setting $Medium
	floatProp centerTrackingDeadZoneMagnitude 30
   setting $High
end
option EnableLotImpostersInLot
	setting $On
		boolProp enableLotImpostersInLot true
	setting $Off
		boolProp enableLotImpostersInLot false
end
option EnableNeighborhoodOccupantsInLot
	setting $On
		boolProp enableNeighborhoodOccupantsInLot true
	setting $Off
		boolProp enableNeighborhoodOccupantsInLot false
end
option LotSkirtSizeIncrease
	setting 0
		uintProp lotSkirtSizeIncrease 5
	setting 1
		uintProp lotSkirtSizeIncrease 9
	setting 2
		uintProp lotSkirtSizeIncrease 18
	setting 3
		uintProp lotSkirtSizeIncrease 36
end
log $logGroup $logLevelDebug "Finished parsing option definitions"
# Hardware Rendering
# This cannot be defined as a local variable, the if clause is still executed when
#   sw render path is taken and an exception generated that fails the parsing.  Be
#   careful with the use of local variables.
setb usingHighDetail false
   # set a base level of options based on the card rating
   if (($memory >= $memoryLevelHigh) and ($cpuSpeed >= $cpuLevelHigh) and ($maxVertexProgramVersionHWMajor >= 1) and not $forceLowSettings and not $isIntegratedChipset)
      log $logGroup $logLevelInfo "Selecting High base level"
      setOption OpaqueUI              $Off
      setOption LivePIP               $On
      setOption Reflection            $On
      setOption Ceiling               $On
      setOption EffectsQuality        $High
      setOption LightingQuality       $High
      setOption Shadows               $High
      setOption MaterialDetail        $High
      setOption ObjectDetail          $High
      setOption ObjectHiding          $Off
      setOption SubjectTracking       $High
      setOption EnableLotImpostersInLot          $On
		setOption EnableNeighborhoodOccupantsInLot $On
		setOption LotSkirtSizeIncrease             1
		setb usingHighDetail true #use this to test if current level is set to high
   elseif (($memory >= $memoryLevelMedium) and ($cpuSpeed >= $cpuLevelMedium) and ($maxVertexProgramVersionHWMajor >= 1) and not $forceLowSettings)
      log $logGroup $logLevelInfo "Selecting Medium base level"
      setOption Reflection            $Off
      setOption Ceiling		          $Off
      setOption EffectsQuality        $Medium
      setOption LightingQuality       $Medium
      setOption Shadows               $Medium
      setOption MaterialDetail        $Medium
      setOption ObjectHiding          $On
      setOption SubjectTracking       $Medium
		setOption LotSkirtSizeIncrease             0
   else
      log $logGroup $logLevelInfo "Selecting Low base level"
      # NOTE: don't set forceLowSettings here, because this will force low simulator settings
      # if all you have is a low end video card
      setOption LivePIP               $Off
      setOption EffectsQuality        $Low
      setOption LightingQuality       $Low
      setOption Shadows               $Low
      setOption MaterialDetail        $Low
      setOption ObjectDetail          $Medium
      setOption SubjectTracking       $Low
      setOption EnableLotImpostersInLot          $Off
		setOption EnableNeighborhoodOccupantsInLot $Off
   endif
   setOption LightingOptimizations $High
   setOption SnowOnGround          $On
   # adjust simulator based on cpu speed
   # adjust the sound quality based on cpu speed (this may be overridden below for low-end systems)
   # adjust animation sampling based on cpu speed
   if ($cpuSpeed >= $cpuLevelHigh and not $forceLowSettings)
      setOption SimulatorControls      $High
      setOption SoundQuality           $High
      setOption AnimationSamplingLevel $Medium
   elseif ($cpuSpeed >= $cpuLevelMedium and not $forceLowSettings)
      setOption SimulatorControls      $Medium
      setOption SoundQuality           $Medium
   else
      setOption SimulatorControls      $Low
      setOption SoundQuality           $Low
      setOption AnimationSamplingLevel $Low
   endif
   # turn off fullscreen fade
   setOption FullscreenFadeEffect    $Off
   if ($textureMemory >= 128 and not $isIntegratedChipset)
      setOption FullscreenFadeEffect $On
   endif
   # screen res defaults
   if (($maxVertexProgramVersionHWMajor >= 1) and ($textureMemory >= 128) and not $forceLowResolution)
      setOption ScreenModeResolution $High
   elseif ($textureMemory >= 64 and not $forceLowResolution)
      if (($memory <= $memoryLevelLow) and ($cpuSpeed <= $cpuLevelLow))
         setOption ScreenModeResolution $MediumButDefaultLow
      else
      endif
   else
      setOption ScreenModeResolution $Low
   endif
   if ($defaultLowResolution)
   endif
   # special event cameras for cinematics
   if (($maxPixelProgramVersionMajor >= 1) and ($supportsSpecialEventCamera))
      setOption SpecialEventCamera $On
   else
   endif
   # set dirty rect mode
   if ($supportsDirtyRect)
      setOption DirtyRect $Medium
   else
      setOption DirtyRect $High
   endif
   # set turbo mode
   if ($supportsTurboRect)
      setOption Turbo $Medium
   else
      setOption Turbo $Low
   endif
   if ($forceMediumMaterialDetail and ($memory >= $memoryLevelHigh) and ($cpuSpeed >= $cpuLevelHigh) and not $forceLowSettings)
      log $logGroup $logLevelWarning "Setting Material Detail"
   endif
   if ($usingHighDetail and not $forceLowSettings)
      if ($forceMediumShadows)
      endif
      if ($forceMediumObjectDetail)
      endif
   endif
endif
# Software rendering
# set the options for the software rasterizer
   if ($cpuSpeed >= $cpuLevelHigh)
      setOption SimulatorControls  $Medium # one lower than hw
   else
   endif
endif
# save the selected configuration for this device.
boolProp activeDeviceUseSoftwareRasterizer $useSoftwareRasterizer
# tell the caller that we completely finished parsing the script
intProp configParserErrorCode 0
uintProp hwMajorPSVersion $maxPixelProgramVersionMajor
log $logGroup $logLevelInfo "Finished Config File"
