Get Sims 2 Ultimate Collection (all DLC) for free
Thanks for the reply, I've done that and I still can't select either of those options so no idea. Also when I'm creating a Sim the box for changing facial features is in the way of my Sim's face so I can't even see what I'm changing. This happens even when the view is zoomed out as far as it can go. :confused:
heres the thread I used
http://www.leefish.nl/mybb/showthread.php?tid=5446
towards the end someone is linking premade config files for different gfx cards but you might need to go back 5 pages or so to find them
edit: here seems to be the 7900 series one
http://www.leefish.nl/mybb/showthread.php?tid=5446&pid=29062#pid29062
When installing your graphic cards.sgr - the folders have changed -
They need to be in
\Origin Games\Fun with Pets\SP9\TSData\Res\Config\
\Origin Games\Fun with Pets\SP9\TSData\Res\CsConfig\
Documents\EA Games\The Sims™ 2 Ultimate Collection\Logs\YOURPCNAME-config-log.txt
Post yours here and we can all have a lookie
Here's mine:
=== Graphics device info ===
Number: 0
Name (driver): AMD Radeon HD 7800 Series
Name (database): Radeon HD 7800 Series
Vendor: ATI
Chipset: Vendor: 1002, Device: 6818, Board: 27401462, Chipset: 0000
Driver: aticfx32.dll, Version: 8.17.10.1267, GUID: D7B71EE2-2B58-11CF-2173-4A07BEC2C535
Driver version: 1267
Monitor: \\.\DISPLAY1
Monitor aspect: 1.776902, 16:9
Screen mode: 1920x1080x32BPP,60Hz
Texture memory: 32MB
HW T&L: Fixed function:1 Programmable:3.0
Pixel program: 3.0
Texture stages: 8
AppControlledAA: 1
It only says I have 32MB of VRAM so obviously I've not done something properly here.
They need to be in
\Origin Games\Fun with Pets\SP9\TSData\Res\CsConfig\[/B]
I've copied my Video Cards.sgr into both of those folders as only one had the changes in it, I'll just boot the game up now and see if anything has changed. Thanks for the help so far guys. :)
EDIT: Arknor, I've downloaded the premade config files for my graphics card and now I can change the edge smoothing and all the other graphical options so thanks for that! All I need to do now is go back into the config files and change the resolution as it seems to be limited to 1600 by something or other. Thanks for the help both. :)
Redeemed the code, downloaded it, couldn't get the game to launch. Got in touch with EA who solved it and gave me a 15% discount code!
Ta very muchly!
Here's mine:
[/B]
You need to set the number so search for seti texture and change it to this
seti textureMemory 1744
in
C:\Program Files (x86)\Origin Games\The Sims 2 Ultimate Collection\Fun with Pets\SP9\TSData\Res\Config\GraphicRules.sgr
Sorry I am a tad drunk tonight, 2 weeks of work coming up and Holiday timeeee. But if you set that it will remove that 32 part and you should have axxs to the other options.
I would not have downloaded any files as you have no need to.
in
It's sorted now! I could have fixed it following your instructions in this post but went the lazy option and download the config files that already had the modern graphics cards added to it. Thanks for the help! Not sure if you can help with another issue I'm having though. When I create a Sim the sliders and such are in the way of the actual Sim so I can't see what effects my changes are having. I've zoomed out but it doesn't actually zoom far enough and the boxes are still in the way of my Sim.
I've downloaded and applied the camera fixes for higher resolutions and the problem persists.
Yep, SoulWings just above. The critique levied at Origin makes zero sense sometimes, I know it's general EA hate but the platform on its own, is serviceable and actually better than Steam imo. For one the UI isn't a chore to navigate.
I don't really have anything against Origin, but I just don't want to have to run multiple platforms on my machine, and overall Steam is better just because of the sheer number of games available on it (I agree that whether the platform itself is any better is debatable).
I forgot how boring the sims was...
barely any different types of furniture etc even though the ultimate edition contains supposedly like 10 expansion packs or something ridiculous like that too...
Followed all the steps to the letter but can't get it to run in 1920x1080!
My log shows the following:
Number: 0
Name (driver): NVIDIA GeForce GTX 770
Name (database): NVIDIA GeForce GTX 770 <<NOT FOUND IN DATABASE!>>
Vendor: NVIDIA
Chipset: Vendor: 10de, Device: 1184, Board: 28251462, Chipset: 00a1
Driver: nvd3dum.dll, Version: 9.18.13.3788, GUID: D7B71E3E-52C4-11CF-1E79-28081CC2C435
Driver version: 3788
Monitor aspect: 1.778156, 16:9
Texture memory: 4032MB
Pixel program: 3.0
Texture stages: 8
AppControlledAA: 1
Tried to get the chip type but mine does not show a hex code, just the name of the card.
EDIT: Looks like the CHIP ID was in the above log (1184) so added that to the 'Videos Card' file but still the same :(
I have the ability to change all settings to High (Shadows is greyed out), it's just the res I can't change!
Can you double check 100% you changed the settings to this:
seti Low 3
seti Medium 3
seti High 3
That part is key, they already exist so make sure you did not just add it and actually changed the values.
Also I think texture memory has to be 1744 even if your card has 4gb. Apart from that no idea sorry.
Yea, they're all set correctly...
seti Off 0
seti On 1
seti Low 3
seti Medium 3
seti High 3
option ScreenModeResolution
setting $Low
uintProp maxResWidth 1920
uintProp maxResHeight 1080
uintProp defaultResWidth 800
uintProp defaultResHeight 600
setting $MediumButDefaultLow
setting $Medium
uintProp defaultResWidth 1024
uintProp defaultResHeight 768
setting $High
end
seti MediumButDefaultLow 4
seti memoryLevelHigh 512
seti memoryLevelMedium 384
seti memoryLevelLow 256
seti memoryLevelUnknown 0
I have attached mine below, back yours up and replace the entire thing with this. Apart from doing that I have no idea m8 sorry, I know mine works doing this:
# Logging settings
set logGroup "ConfigurationManager"
set logLevelWarning warning
set logLevelInfo info
set logLevelDebug debug
log $logGroup $logLevelInfo "Parsing configuration script"
# Constants
seti Off 0
seti On 1
seti Low 3
seti Medium 3
seti High 3
if ( match("${osVersion}","*NT 6.0*") )
seti cpuLevelHigh 3000
seti cpuLevelMedium 2600
seti cpuLevelLow 2000
log $logGroup $logLevelInfo "Setting cpu level for Vista."
else
seti cpuLevelHigh 2800
seti cpuLevelMedium 2200
seti cpuLevelLow 1450
log $logGroup $logLevelInfo "Setting cpu level for non-Vista."
endif
seti cpuLevelUnsupported 0
# Identify gfx device
# set some config variables based on a card table and vendor specific rules
# sets isCardFound, cardVendor, and cardName
include "Video Cards.sgr"
# Fallback on the card name text supplied by the card itself.
# Assumes that at least the cardVendor has been matched, since
# vendor name is not contained in some vendor card names.
# Note that specific vendors are overridden to a default card.
# For ATI -> Radeon 9800 Pro
# For NVIDIA -> NVIDIA 4800 TI SE
if (not $isCardFound)
set cardName $cardNameText
endif
# Configuration override controlled by command line option -cardConfig.
if (varExists(cardConfig))
# test unsupported cards using sw rendering
if ($cardConfig = 1)
log $logGroup $logLevelInfo "Testing with all devices unsupported."
set cardVendor TestingAllUnsupported
set cardName TestingAllUnsupported
elseif (($cardConfig = 2) and ($deviceNumber = 0))
log $logGroup $logLevelInfo "Testing with the first device unsupported."
set cardVendor TestingFirstUnsupported
set cardName TestingFirstUnsupported
elseif (($cardConfig = 3) and ($deviceNumber != 0))
log $logGroup $logLevelInfo "Testing with the all devices except first unsupported."
set cardVendor TestingAllButFirstUnsupported
set cardName TestingAllButFirstUnsupported
elseif (($cardConfig = 100) and ($deviceNumber = 0))
log $logGroup $logLevelInfo "Testing first device as swvp only part."
boolProp forceSoftwareVP true
endif
endif
# Determine if gfx device is supported, force software rendering if not
setb useSoftwareRasterizer false
if (match("${cardVendor}", "ATI"))
if (match("${cardName}", "*Mach*") or match("${cardName}", "*Rage*"))
setb useSoftwareRasterizer true
endif
elseif (match("${cardVendor}", "NVidia"))
if (match("${cardName}", "NV 1") or match("${cardName}", "NV 2") or match("${cardName}", "*Riva*") or match("${cardName}", "*TNT*"))
endif
elseif (match("${cardVendor}", "Intel"))
if (match("${cardName}", "*810*") or match("${cardName}", "*815*") or match("${cardName}", "*740*") or match("${cardName}", "*752*"))
endif
elseif (match("${cardVendor}", "S3"))
if (not match("${cardName}", "*GammaChrome*") and not match("${cardName}", "*DeltaChrome*"))
endif
else
# unsupported/unknown vendor
endif
if ($useSoftwareRasterizer)
log $logGroup $logLevelWarning "Unsupported video card. Forcing software rendering on this device"
else
log $logGroup $logLevelInfo "Supported video card."
endif
if (not $useSoftwareRasterizer)
# failed to obtain device texture memory size, force to 32MB
if ($textureMemory = 0)
setb textureMemorySizeOK false
endif
if ($textureMemory < 28)
log $logGroup $logLevelWarning "Insufficient video memory. Forcing software rendering on this device"
# require a card with at least 32MB
endif
endif
# ignore texture memory reported by gfx device, this is not hardware texture memory
seti textureMemory 32
endif
log $logGroup $logLevelInfo "Hardware rendering is enabled"
endif
# Apply gfx device specific workarounds
# Available device props:
# forceSoftwareVP
# forceSoftwareDevice
# queriesOK
# windowedModeFormatConversionOK
# enumerateMultisampleLevels
# skipValidateDevice
# enableDriverMemoryManager
# softwareDeviceLocalVideoMemorySize
# deviceLocalVideoMemorySizeDefault
# disableVSyncSupport
# substituteFlipForDiscardSwapEffect
# minTextureDimensionForBalance
# Additional props:
# vs2LoopsFunctional
setb textureMemorySizeOK true
setb supportsDirtyRect true
setb supportsTurboRect true
setb supportsSpecialEventCamera true
setb forceLowSettings false
setb forceLowResolution false
setb defaultLowResolution false
setb forceMediumMaterialDetail false
setb isIntegratedChipset false
setb forceMediumShadows false
setb forceMediumObjectDetail false
boolProp useRenderTextures false
uintProp antialiasingSupport 1
boolProp dontMergeNHFlora true
# never trust the driver to manage its own memory
boolProp enableDriverMemoryManager false
boolProp vs2LoopsFunctional false
boolProp presentWorkaround false
boolProp enumerateMultisampleLevels true
# not enough texture memory for antialiasing
if ($textureMemory < 127)
boolProp enumerateMultisampleLevels false
endif
if (match("${cardVendor}", "NVIDIA"))
# on NVidia cards, create a dummy texture on device creation to prevent BSODs
boolProp createNVidiaWorkaroundTexture true
if ($appControlledAA)
# nvidia drivers handle offscreen aa
uintProp antialiasingSupport 3
else
# remove this when the texture manager balancing is fixed.
boolProp disableTexMemEstimateAdjustment true
# turn off dirty rects
setb supportsDirtyRect false
endif
if (match("${cardName}", "*GeForce2*Integrated*") or match("${cardName}", "*GeForce?2*Integrated*") or match("${cardName}", "*GeForce4*Integrated*") or match("${cardName}", "*GeForce?4*Integrated*") or match("${cardName}", "*GeForce2 Quadro2 Pro*"))
boolProp causticsEnabled false
setb forceLowSettings true
setb forceLowResolution true
endif
# the 6200 Turbo Cache peformed very poorly in CATLAB runs for EP2
if (match("${cardName}", "*6200 TC*") or match("${cardName}", "*6100*"))
setb defaultLowResolution true
endif
# need to get around the problem of z fighting in GeForce4 cards
if (match("${cardName}", "*GeForce4*"))
boolProp raiseLightSnowFF true
endif
# disable shaders by default for NV3x generation, only enable for high end cards
if ($maxVertexProgramVersionHWMajor = 2)
boolProp useShaders false
if (match("${cardName}", "GeForceFX*") or match("${cardName}", "*GeForce?FX*"))
if (match("${cardName}", "*57?0*") or match("${cardName}", "*58?0*") or match("${cardName}", "*59?0*"))
boolProp useShaders true
log $logGroup $logLevelInfo "Enabling shaders for high-end NV3x"
endif
if (match("${cardName}", "*NV35*") or match("${cardName}", "*NV36*") or match("${cardName}", "*NV38*") or match("${cardName}", "*NV39*"))
endif
# 5700 cards sometimes have problems with bump mapping so setting default to medium
if (match("${cardName}", "*5700*"))
log $logGroup $logLevelInfo "Forcing Medium Material detail on 5700"
setb forceMediumMaterialDetail true
endif
if (match("${cardName}", "*5700LE*"))
log $logGroup $logLevelInfo "Forcing low settings on 5700LE and 6100"
endif
endif
if (match("${cardName}", "QuadroFX*") or match("${cardName}", "*Quadro?FX*"))
if (match("${cardName}", "*3000*") or match("${cardName}", "*1?00*"))
log $logGroup $logLevelInfo "Enabling shaders for high-end NV3x Quadro"
endif
if (match("${cardName}", "*2000*") or match("${cardName}", "*1000*") or match("${cardName}", "*1300*"))
log $logGroup $logLevelInfo "Disabling caustics as these cause cards cause problems with shadows"
endif
endif
# caps read vs 3.0, but dx9b is returning vs 2.0, once 9c is used this fix can be removed
if (match("${cardName}", "*GeForce*"))
if (match("${cardName}", "*68?0*"))
log $logGroup $logLevelInfo "Enabling shaders for high-end NV40 Parts on Dx9b"
endif
endif
endif
if ($maxVertexProgramVersionHWMajor = 0)
boolProp skipValidateDevice true
log $logGroup $logLevelInfo "Enabling D3DERR_CONFLICTINGRENDERSTATE validation workaround"
endif
elseif (match("${cardVendor}", "ATI"))
# loops support broken in 6458. Fixed in catalyst 4.9 (6476) but we require 4.10 to be safe.
if ($driverBuild >= 6476)
boolProp vs2LoopsFunctional true
endif
# workaround for forced aa crash as of 6458. Fixed in catalyst 4.9 (6476) but we require 4.10 to be safe.
# TODO: this is not yet enabled, pending testing
#if ($driverBuild < 6476)
boolProp useRenderTextures true
#endif
# avoid a race condition with color copies and ui
boolProp presentWorkaround true
if (match("${cardName}", "*Radeon?VE*") or match("${cardName}", "*7?00*") or match("${cardName}", "*R100*") or match("${cardName}", "*IGP 3?0*") or match("${cardName}", "*9100 IGP*"))
log $logGroup $logLevelInfo "Forcing turbo rects off"
setb supportsTurboRect false
boolProp simpleTerrain true
if (match("${cardName}", "*9100 IGP*"))
log $logGroup $logLevelInfo "Forcing low resolution"
endif
if (match("${cardName}", "*Radeon?VE*") or $driverBuild < 6414)
log $logGroup $logLevelInfo "Forcing swvp"
endif
endif
if (match("${cardName}", "*X1300*") or match("${cardName}", "*X300*") or match("${cardName}", "*XPRESS 200*"))
log $logGroup $logLevelInfo "Forcing medium settings or lower"
endif
boolProp usePS30 false
if ($maxVertexProgramVersionHWMajor < 2)
# Radeon 8500 and greater have problems switching between FF and VS?
log $logGroup $logLevelInfo "Forcing shaders of for ATI DX8"
endif
if (match("${cardName}", "*8500*"))
#avoid z fighting with light snow
endif
if (match("${cardName}", "*9600 SE *"))
setb forceMediumShadows true
setb forceMediumObjectDetail true
endif
if (match("${cardName}", "*Mobility*"))
setb isIntegratedChipset true
endif
# X800 based cards exhibit rendering corruption if turbo rect is enabled
if (match("${cardName}", "*X800*") or match("${cardName}", "*R420*"))
endif
if (match("${cardName}", "*92?0*"))
log $logGroup $logLevelInfo "Forcing shadow detail on 9250 and 9200"
endif
if (match("${cardName}", "*GammaChrome*") or match("${osVersion}","*NT 6.0*") )
log $logGroup $logLevelInfo "Forcing Gamma Chrome to use fixed function shaders"
endif
# EP6 CATlab reports gray screen during all cinematics
if (match("${cardName}", "*S27*"))
setOption SpecialEventCamera $Off
endif
if (match("${cardName}", "*X3000*"))
boolProp disableVSyncSupport true # work around flickering UI
else
boolProp useShaders false # (EP2 change) mostly for performance, but driver issues showed up in v14.14
endif
# the Intel minspec driver doesn't misreport available texture memory, so it's not
# necessary to adjust the texture memory estimate it returns. This may also fix
# a Windows "device failure" message that occurs sometimes on this device.
# assuming Intel parts are UMA, drop the texture memory to 32 if not much system memory
if ($memory <= $memoryLevelLow)
if ($textureMemory > 32)
endif
endif
if (match("${cardName}", "*845*") or match("${cardName}", "*865*") or match("${cardName}", "*830*") or match("${cardName}", "*855*"))
endif
# the 915 sets the caps bit that indicates it can do texture projection,
# but does it incorrectly in the pixel stage. Here we override the texture
# projection cap we get from the device.
if (match("${cardName}", "*915*"))
boolProp disableTextureProjection true
endif
endif
intProp deviceLocalVideoMemorySizeDefault ($textureMemory * 1024 * 1024)
else
# force sw, swvp, and no aa
boolProp forceSoftwareDevice true
intProp softwareDeviceLocalVideoMemorySize ($textureMemory * 1024 * 1024)
endif
# since we don't do bumpmapping on less ps2.0-capable hardware, eliminate tangents
# from the vertex data
# also, the presence of per-vertex tangents in the vertex data stream causes
# "exploded" polygons on the Radeon 9000, even if the data is ignored by the shader
if ($maxPixelProgramVersionMajor < 2)
boolProp skipTangentsInVertexData true
endif
# Print system info
if ($deviceNumber = 0)
logSystemInfo "=== Application info ==="
logSystemInfo "Name: ${appName}"
logSystemInfo "Version: ${version}"
logSystemInfo "Build: ${buildType}"
logSystemInfo "=== Machine info ==="
logSystemInfo "OS version: ${osVersion}"
logSystemInfo "CPU: ${cpuSpeed}Mhz, Name:${CPU}, FPU:${FPU}, MMX:${MMX}"
logSystemInfo "Memory: ${memory}MB"
logSystemInfo "Free memory: ${freeMemory}MB"
logSystemInfo "User: ${userName}"
logSystemInfo "Computer: ${computerName}"
logSystemInfo "=== Sound device info ==="
logSystemInfo "Name: ${soundCardName}"
logSystemInfo "Driver: ${soundDriverName}"
endif
logSystemInfo "=== Graphics device info ==="
logSystemInfo "Number: ${deviceNumber}"
logSystemInfo "Name (driver): ${cardNameText}"
if ($isCardFound)
logSystemInfo "Name (database): ${cardName}"
else
logSystemInfo "Name (database): ${cardName} <<NOT FOUND IN DATABASE!>>"
endif
if ($isIntegratedChipset)
logSystemInfo " (Integrated Chipset)"
endif
logSystemInfo "Vendor: ${cardVendor}"
logSystemInfo "Chipset: ${cardChipset}"
logSystemInfo "Driver: ${driverName}, Version: ${driverVersion}"
logSystemInfo "Driver version: ${driverBuild}"
logSystemInfo "Monitor: ${monitorName}"
logSystemInfo "Monitor aspect: ${monitorAspect}, ${monitorAspectString}"
logSystemInfo "Screen mode: ${screenWidth}x${screenHeight}x${screenBPP}BPP,${screenRefresh}Hz"
if ($textureMemorySizeOK)
logSystemInfo "Texture memory: ${textureMemory}MB"
else
logSystemInfo "Texture memory: ${textureMemory}MB <<OVERRIDE>>"
endif
logSystemInfo "HW T&L: Fixed function:${fixedFunctionHWTnL} Programmable:${maxVertexProgramVersionHWMajor}.${maxVertexProgramVersionHWMinor}"
logSystemInfo "Pixel program: ${maxPixelProgramVersionMajor}.${maxPixelProgramVersionMinor}"
logSystemInfo "Texture stages: ${textureStages}"
logSystemInfo "AppControlledAA: ${appControlledAA}"
# UI Options
log $logGroup $logLevelDebug "Begin parsing option definitions"
option MaterialDetail
setting $Low
boolProp bumpMapping false
intProp imageDataSizeReductionOnLoad 2
setting $Medium
intProp imageDataSizeReductionOnLoad 1
setting $High
boolProp bumpMapping true
intProp imageDataSizeReductionOnLoad 0
end
option ObjectDetail
setting $Medium
boolProp reduceBoneWeights true
boolProp useLODs true
intProp lodOverride 35
setting $High
boolProp reduceBoneWeights false
boolProp useLODs false
intProp lodOverride 0
end
option ObjectHiding
setting $Off
intProp renderInsideVisibleObjects 0
setting $On
intProp renderInsideVisibleObjects 1
end
option SnowOnGround
setting $Off
boolProp showSnowOnGround false
setting $On
boolProp showSnowOnGround true
end
option Shadows
setting $Low
boolProp simShadows false
boolProp objectShadows false
boolProp guob false
boolProp heightMapShadows false
setting $Medium
boolProp guob true
boolProp heightMapShadows true
setting $High
boolProp simShadows true
boolProp objectShadows true
boolProp guob true
end
option OpaqueUI
setting $Off
boolProp renderOpaqueUI false
setting $On
boolProp renderOpaqueUI true
end
option Reflection
setting $Off
boolProp reflectionWithExtraViewer false
boolProp nhoodWaterReflection false
setting $On
boolProp reflectionWithExtraViewer true
boolProp nhoodWaterReflection true
end
option Ceiling
setting $Off
boolProp includeCeilings false
setting $On
boolProp includeCeilings true
end
option EffectsQuality
setting $Low
boolProp useEffects true
floatProp particleDensity 1
floatProp particleScale 1
intProp maxParticlesTarget 2000
intProp particleLODOffset 0 # subtracted from the zoom.
intProp effectPriorityLevel 1
boolProp enableOceanReflection false
setting $Medium
intProp maxParticlesTarget 5000
intProp effectPriorityLevel 2
setting $High
intProp maxParticlesTarget 10000
intProp effectPriorityLevel 3
boolProp enableOceanReflection true
end
option LightingQuality
setting $Low
boolProp lightingEnabled true
boolProp portalLighting false
boolProp floorAndWallNormalMapping false
boolProp specHighlights false
setting $Medium
boolProp portalLighting true
boolProp specHighlights true
setting $High
boolProp floorAndWallNormalMapping true
end
option SoundQuality
setting $Low
intProp AudioPerformance 0
setting $Medium
intProp AudioPerformance 1
setting $High
intProp AudioPerformance 2
end
# Options without ui access.
option DirtyRect
setting $High
# no dirty rects
intProp dynamicRenderStrategy 0
setting $Medium
# 4 buffer mode
intProp dynamicRenderStrategy 2
setting $Low
# 2 buffer mode
intProp dynamicRenderStrategy 1
end
option FullscreenFadeEffect
setting $Off
boolProp enableSnapshot false
setting $On
boolProp enableSnapshot true
end
option Turbo
setting $High
boolProp useTurboRect true
setting $Medium
setting $Low
boolProp useTurboRect false
end
option SimulatorControls
setting $High
intProp maxNumOfVisitingSims 8
setting $Medium
intProp maxNumOfVisitingSims 6
setting $Low
intProp maxNumOfVisitingSims 2
end
option LightingOptimizations
setting $High
boolProp optimizedDiffusion true
boolProp incrementalLighting true
boolProp lerpLights true
boolProp useDirtyTiles true
end
option AnimationSamplingLevel
setting $Low
# sample nearest animation frame
boolProp animationFrameSampling true
setting $Medium
# sample nearest two animation frames and slerp
boolProp animationFrameSampling false
end
option LivePIP
setting $Off
boolProp livePIP false
boolProp livePIPDefault false
setting $On
boolProp livePIPDefault true
# do not override user's choice if the setting is ON
end
option SpecialEventCamera
setting $Off
boolProp chooseCameraSpecialEventEnabled false
boolProp CameraSpecialEventEnabled false
setting $On
boolProp chooseCameraSpecialEventEnabled true
end
setting $Low
setting $Medium
setting $High
end
option SubjectTracking
setting $Low
floatProp centerTrackingDeadZoneMagnitude 70
setting $Medium
floatProp centerTrackingDeadZoneMagnitude 30
setting $High
end
option EnableLotImpostersInLot
setting $On
boolProp enableLotImpostersInLot true
setting $Off
boolProp enableLotImpostersInLot false
end
option EnableNeighborhoodOccupantsInLot
setting $On
boolProp enableNeighborhoodOccupantsInLot true
setting $Off
boolProp enableNeighborhoodOccupantsInLot false
end
option LotSkirtSizeIncrease
setting 0
uintProp lotSkirtSizeIncrease 5
setting 1
uintProp lotSkirtSizeIncrease 9
setting 2
uintProp lotSkirtSizeIncrease 18
setting 3
uintProp lotSkirtSizeIncrease 36
end
log $logGroup $logLevelDebug "Finished parsing option definitions"
# Hardware Rendering
# This cannot be defined as a local variable, the if clause is still executed when
# sw render path is taken and an exception generated that fails the parsing. Be
# careful with the use of local variables.
setb usingHighDetail false
# set a base level of options based on the card rating
if (($memory >= $memoryLevelHigh) and ($cpuSpeed >= $cpuLevelHigh) and ($maxVertexProgramVersionHWMajor >= 1) and not $forceLowSettings and not $isIntegratedChipset)
log $logGroup $logLevelInfo "Selecting High base level"
setOption OpaqueUI $Off
setOption LivePIP $On
setOption Reflection $On
setOption Ceiling $On
setOption EffectsQuality $High
setOption LightingQuality $High
setOption Shadows $High
setOption MaterialDetail $High
setOption ObjectDetail $High
setOption ObjectHiding $Off
setOption SubjectTracking $High
setOption EnableLotImpostersInLot $On
setOption EnableNeighborhoodOccupantsInLot $On
setOption LotSkirtSizeIncrease 1
setb usingHighDetail true #use this to test if current level is set to high
elseif (($memory >= $memoryLevelMedium) and ($cpuSpeed >= $cpuLevelMedium) and ($maxVertexProgramVersionHWMajor >= 1) and not $forceLowSettings)
log $logGroup $logLevelInfo "Selecting Medium base level"
setOption Reflection $Off
setOption Ceiling $Off
setOption EffectsQuality $Medium
setOption LightingQuality $Medium
setOption Shadows $Medium
setOption MaterialDetail $Medium
setOption ObjectHiding $On
setOption SubjectTracking $Medium
setOption LotSkirtSizeIncrease 0
else
log $logGroup $logLevelInfo "Selecting Low base level"
# NOTE: don't set forceLowSettings here, because this will force low simulator settings
# if all you have is a low end video card
setOption LivePIP $Off
setOption EffectsQuality $Low
setOption LightingQuality $Low
setOption Shadows $Low
setOption MaterialDetail $Low
setOption ObjectDetail $Medium
setOption SubjectTracking $Low
setOption EnableLotImpostersInLot $Off
setOption EnableNeighborhoodOccupantsInLot $Off
endif
setOption LightingOptimizations $High
setOption SnowOnGround $On
# adjust simulator based on cpu speed
# adjust the sound quality based on cpu speed (this may be overridden below for low-end systems)
# adjust animation sampling based on cpu speed
if ($cpuSpeed >= $cpuLevelHigh and not $forceLowSettings)
setOption SimulatorControls $High
setOption SoundQuality $High
setOption AnimationSamplingLevel $Medium
elseif ($cpuSpeed >= $cpuLevelMedium and not $forceLowSettings)
setOption SimulatorControls $Medium
setOption SoundQuality $Medium
else
setOption SimulatorControls $Low
setOption SoundQuality $Low
setOption AnimationSamplingLevel $Low
endif
# turn off fullscreen fade
setOption FullscreenFadeEffect $Off
if ($textureMemory >= 128 and not $isIntegratedChipset)
setOption FullscreenFadeEffect $On
endif
# screen res defaults
if (($maxVertexProgramVersionHWMajor >= 1) and ($textureMemory >= 128) and not $forceLowResolution)
setOption ScreenModeResolution $High
elseif ($textureMemory >= 64 and not $forceLowResolution)
if (($memory <= $memoryLevelLow) and ($cpuSpeed <= $cpuLevelLow))
setOption ScreenModeResolution $MediumButDefaultLow
else
endif
else
setOption ScreenModeResolution $Low
endif
if ($defaultLowResolution)
endif
# special event cameras for cinematics
if (($maxPixelProgramVersionMajor >= 1) and ($supportsSpecialEventCamera))
setOption SpecialEventCamera $On
else
endif
# set dirty rect mode
if ($supportsDirtyRect)
setOption DirtyRect $Medium
else
setOption DirtyRect $High
endif
# set turbo mode
if ($supportsTurboRect)
setOption Turbo $Medium
else
setOption Turbo $Low
endif
if ($forceMediumMaterialDetail and ($memory >= $memoryLevelHigh) and ($cpuSpeed >= $cpuLevelHigh) and not $forceLowSettings)
log $logGroup $logLevelWarning "Setting Material Detail"
endif
if ($usingHighDetail and not $forceLowSettings)
if ($forceMediumShadows)
endif
if ($forceMediumObjectDetail)
endif
endif
endif
# Software rendering
# set the options for the software rasterizer
if ($cpuSpeed >= $cpuLevelHigh)
setOption SimulatorControls $Medium # one lower than hw
else
endif
endif
# save the selected configuration for this device.
boolProp activeDeviceUseSoftwareRasterizer $useSoftwareRasterizer
# tell the caller that we completely finished parsing the script
intProp configParserErrorCode 0
uintProp hwMajorPSVersion $maxPixelProgramVersionMajor
log $logGroup $logLevelInfo "Finished Config File"
