Corsodyl Daily Gum & Tooth Paste - This stuff?
Why not just floss?
Every dentist i've been too as part of a clean, still used floss, and not the high pressure water. So flossing must still be better.
Using a Airfloss, or similar, is a hell of a lot quicker and easier than flossing. I have quite cramped teeth in places too which makes getting floss in there pretty hard.
I don't doubt actually flossing is actually better, but I think the Airfloss is a good compromise and given it is so easy to do means I do it every night as opposed to every now and then with traditional flossing.
Why not just floss?
I use the t-pee pieces between my teeth, which are effective.
Mine has a separate hygienist and she uses both, one after the other.Every dentist i've been too as part of a clean, still used floss, and not the high pressure water. So flossing must still be better.
'Mineral grit'?If these are half as good as the Corsodyl daily toothpaste with the mineral grit i got then i will be amazed.
The jet is for any tartar/plaque buildup.
Ermmm. Are you quite sure she wasn't using a scaler to remove the tartar, rather than a water jet?
So...what you're basically saying is you're too lazy to floss?
Do you get the choice of a lollipop or a sticker at the end?Hmmm... Could well be. She just calls it the jet washer...
Nah, it's a Private practice. They only offer Audis or Aston Martins...Do you get the choice of a lollipop or a sticker at the end?![]()
water erodes mountains so will it erode your teeth
