You don't understand evolution because if you did you wouldn't be expressing such ignorant opinions. Micro evolution and Macro evolution are both evolution, the only difference between them is the time scale. Given a long enough period of time, Micro evolution becomes Macro evolution. This is confirmed beyond a reasonable doubt by molecular genetics and is strongly bolstered by the countless thousands of finds in the fossil record which show organisms transitioning over time from one species to another.
One of the Vignettes I posted earlier clearly shows this. Maybe you didn't watch it so here it is again.
Because belief is not a scientific position?
Because science doesn't exist in isolation, or perhaps more accurately, if it does, it cannot be used to challenge anything external to it.
Also, read my earlier posts in the thread about the nature of science, it saves me repeating myself.
Science is true whether or not you believe in it.
/thread
Look, I'm not getting into philosophy because it just muddies the waters. This thread is about Evolution and whether or not people accept it as true. All I'm trying to do is provide the evidence, and there is mountains of it, in order to educate the people who deny evolution because they don't understand how it works. One of the best ways to do this in my opinion, is to use one of the worlds leading evolutionary biologists as a means of conveying some of that evidence. Richard Dawkins is not a philosopher in any real sense, he is first and foremost a man of science. Philosophy won't get you anywhere when you try and study biology and it's origins and ask what mechanisms drive it. Only the scientific method can uncover these answers and these include molecular genetics, paleontology, radiometric dating and geology amongst others.
Just looking at the comments of that Richard Dawkins video, its scary how ignorant people still are.
But the scientific method relies on assumptions that cannot be tested in order to work.
It is perfectly possible to accept evolution as an accurate approach to describe and predict our world without accepting that evolution is true to the point where it excludes all alternatives.
Dawkins' positions on religion, god etc and his published work in this area is exclusively philosophical in nature, not scientific. Science is a big part of the philosophy presented, but that doesn't make the two things interchangeable.
What assumptions are these? I'm not really clear on this.
Evolution is the currently accepted theory and if someone comes up with an evidenced alternative then I will accept. Creation is not an evidenced alternative.
And the millions and millions killed by weapons created using the application of science, the destruction of our ecosystem using the application of science..the creations of schools, libraries, hospitals, scientific discovery itself through the application of Religion...the point I'm making is that you cannot objectively quantify the ratio of good and bad, you can only judge the application of each as it is defined at the time.
No. You don't understand the scientific method. It does not rely on assumptions even if assumptions are made at the start of the process. It starts with observation and then an hypothesis is developed to try and explain that observation. Assumption is the wrong word.
The scientific method is the best way yet discovered for reaching the truth from lies and delusion. The simple version looks something like this:
• 1. Observe some aspect of the universe.
• 2. Invent a tentative description, called a hypothesis, that is consistent with what you have observed.
• 3. Use the hypothesis to make predictions.
• 4. Test those predictions by experiments or further observations and modify the hypothesis in the light of your results.
• 5. Repeat steps 3 and 4 until there are no discrepancies between theory and experiment and/or observation.
Your theory will be subject to peer review by other scientists from around the world. Their aim is to find flaws in your theory and prove it wrong. Once a theory passes this test, it becomes widely accepted as the best possible explanation for the observed phenomena. This does not mean it is not subject to change however if new evidence arrives later.
When consistency is obtained the hypothesis becomes a theory and provides a coherent set of propositions which explain a class of phenomena. A theory is then a framework within which observations are explained and predictions are made.
For some examples:
Parsimony.
Time moves forward.
Accurately observable reality.
Consistent reality.
Repeatability
None of these things matter when you discuss predictive accuracy of a scientific model, because they are accepted to be true, despite being unprovable, within the scientific context.
The problem comes when people want to move science out of the predictive and into the truth. Once you so that, then it becomes a lot less clear because those assumptions that are fine for prediction cannot be stated as true.
Unprovable but I can't see time moving forward not being provable ever being used as an argument against evolution. Nor the others.
If the scientific method can't provide truth then what can? Is all science just merely predictive and not necessarily true?
My degree is in chemistry, I understand the scientific process just fine. What you fail to understand is that the scientific process itself cannot be indepently verified as being a true and valid definition of the universe.
The simple act of applying Ockham's razor to reduce entities beyond necessity, for example, is an act of faith that cannot be proven to represent how the universe actually works.
If you want to put faith in the scientific method to provide truth, as opposed to prediction, go right ahead, but don't pretend it is anything else but your own unprovable belief.
I am extremely grateful my geology degree included studying a little philosophy of science to nip this kind of positivist claptrap in the bud for most of my peers.No. You don't understand the scientific method. It does not rely on assumptions even if assumptions are made at the start of the process. It starts with observation and then an hypothesis is developed to try and explain that observation. Assumption is the wrong word.
at the moment most of those killed by weapons are done so in the name of one god or another..theres very few geo-political wars being fought now, most are fuelled by religious hatred.
