AMD freesync coming soon, no extra costs.... shocker
Waiting for fixes to large issues since they released the product is a poor show IMO. while they do have merits, more often than not it's broken in some form.
Then sell your cards and stop whining then??
That is the answer to everything? Sell up and move on? :rolleyes:
Why didn't I think of that sooner?
I see why people stay away from this section of the forum, the die hard fan boys can't take any criticism on board.
Anything AMD makes will be broken, just like their drivers, mantle and soon freesync.
So what?? I have loads of mates who have had AMD GCN based cards and have been mostly fine under Windows. I have a GTX660 which has had some niggles(well known issues) but has mostly been fine. If there is an issue simply roll back to an earlier driver - Planetside2 started crashing repeatedly on my card with one driver version recently,so I just rolled back to an earlier one,until the problem was solved. Metro:Last Light was known for corruption issues at launch. SR3 and SR4 had problems with some Nvidia driver versions(replicated by other mates with Kepler based cards too). These are all documented.
Looking over the dozens of AMD/ATI and Nvidia cards I have owned and that of mates over the last decade,there have been very few issues per se,and if they are very few have been longterm game breaking ones. However,both do have documented problems.
I have a GTX660 and I am a fanboi now!! :eek:
People like Phixsator and me use Nvidia cards ATM,so when your generalised comments are countered by people you start emo-raging at them.
ROFL,that makes you a fanboi too using your twisted logic,and if anything its people like you with your generalised comments which are the problem in this subform,and honestly if the cards are causing so much problems,stop whinging so much and sell them and get some Nvidia cards.
Considering Maxwell is out soon,a pair of GTX870s probably would be faster than what you have now.
Done.
ROFL,makes you a fanboi too,and honestly if the cards are causing so much problems,stop whinging so much and sell them and get some Nvidia cards.
Considering Maxwell is out soo,a pair of GTX870s probably would be faster than what you have now.
Done.
I think Maxwell will be my next stop. I'm sorry I won't post my concerns and views on my GPU's in the future - I might offend.
Generalized comments? Don't me me laugh.
While i dont agree Everything AMD does is broken,i personally think they make some great stuff,, You are as entitled to post your opinion as anyone,, and i look forward to hearing about your maxwell cards if you go that way
They make excellent hardware and now and then some epic drivers. But there is a lot (maybe too much) broken things in the mix - which either takes too much time to fix or never gets fixed (like the zero core feature) it took 6 months+ for this to work as it was intended.
To be fair Locky, I felt the same about NVidia with my GTX760, my 8800GT, even an old GF2 I had. :p
Why does every single thread have to end in Brand bashing?
All the available information about FreeSync, in one bite size chunk.
Because Project FreeSync obviates the need for v-sync, gamers especially sensitive to input latency — a delay between mouse movement and cursor movement — will also see a distinct increase in responsiveness.
Finally, disabling v-sync would typically introduce nasty horizontal tearing, but Project FreeSync also eliminates tearing as a rule. Project FreeSync is a "best of all worlds" solution from the perspective of smoothness, image quality and responsiveness.
How does Project FreeSync utilize DisplayPort™ Adaptive-Sync to determine the period of time a frame is displayed to the user?
​An AMD Radeon™ graphics card compatible with Project FreeSync uses the DisplayPort™ Adaptive-Sync specification to automatically determine the minimum and maximum refresh rates supported by a dynamic refresh-ready system. Using this approach, no communication must occur to negotiate the time a current frame remains on-screen, or to determine that is safe to send a new frame to the monitor.
By eliminating the need for ongoing communication with pre-negotiated screen update rates, Project FreeSync can execute highly dynamic changes in frame presentation intervals without incurring communications overhead or latency penalties.
Source
http://support.amd.com/en-us/kb-articles/Pages/freesync-faq.aspx
Good info. thanks Matt :)
Richard Huddy Discusses FreeSync Availability Timeframes
At SIGGRAPH, Richard Huddy of AMD announced the release windows of FreeSync, their adaptive refresh rate technology, to The Tech Report. Compatible monitors will begin sampling "as early as" September. Actual products are expected to ship to consumers in early 2015. Apparently, more than one display vendor is working on support, although names and vendor-specific release windows are unannounced.
As for cost of implementation, Richard Huddy believes that the added cost should be no more than $10-20 USD (to the manufacturer). Of course, the final price to end-users cannot be derived from this - that depends on how quickly the display vendor expects to sell product, profit margins, their willingness to push new technology, competition, and so forth.
If you want to take full advantage of FreeSync, you will need a compatible GPU (look for "gaming" support in AMD's official FreeSync compatibility list). All future AMD GPUs are expected to support the technology.
http://www.pcper.com/news/General-Tech/Richard-Huddy-Discusses-FreeSync-Availability-Timeframes
