The fan ramps up but I don't find it overly bad and I hate noise. Did you have them in a well ventilated area ?
I can definitely hear it in the evening as well but I have just learnt to ignore it. Just been playing Watchdogs and it chuffs away.
Do you have an Xbox one they are almost completely silent. MS really got the cooling right with the One.
(I have serious ocd lol)
My girlfriend thinks I'm nuts.
Just an observation really from my experience and that of people I know where all with 1 have some sort of issue with the sticks but 2's seem to be OK.
But then there's people like Captain Planet saying they have wear on both types so it perhaps is just coincidence. On my pads though there is a definite difference in the type of rubber between the two.
Please explain, ta
I have had one replacement pad so far and I bought a spare a couple of months back, only used the replacement pad so far but can't tell if it's wearing yet, it might of a little.
Do you mean serial numbers starting 1 and 2 should be different?
Thanks
)Have any games apart from Killzone actually utilised that touchpad yet?![]()
Got the xbox one thumb sticks fitted, there a huge improvement, been slightly longer it seems to have shifted my hands slightly improving where my fingers are placed on the triggers.
Where you get the sticks, How did you fit the stick surely there not a simple swap
