Might be the wrong time of the year but can anyone recommend a turbo?
Cycleops Fluid 2 worth a look in?
If that falls through, these look like a reasonably similar spec
I (and most on here I think) have the Kurt Kinetic Road Machine
I went out in the rain one dark evening last winter. broke my chain, came home and swapped bikes, snapped a spoke, put in a new wheel and set it up on the turbo.
my cheap turbo wouldn't tighten properly and started wobbling around.
Went off in a rage and bought a Kurt kinetic rock n rollgreat turbo. Takes up a huge amount of space though.
Ah I'd misread tubeless for tubs.
Question for the turbo/roller-ers with a garmin edge and cadence/speed sensor...
Can you get "distance" cycled per workout on the rollers? Or is it just speed/cadence/heart rate/whatever..
Hopefully this doesn't get lost in this thread
Just submitted insurance claim for my bike £1500 now all being well they should payout.
I can't get out to test bikes yet due to my injuries , but I'm window shopping so to speak. I'm looking at putting another £500 towards the bike.
I'm not overly bothered about the quality of wheels on this bike as I have some decent handbuilt wheels.
Any suggestions on what to avoid/have a look at? Been looking at the new trek lightweight frame build.
Any help or suggestions would appreciated
Yep. It's already using the revolutions at the rear wheel to calculate speed, for distance it just counts them up.
That Viking Peloton 700C looks really good. Can't find a store that stocks them locally, would prefer to try one before I hit the Buy button. So far it's between that, the Carrera Subway from Halfords and the Norco Valence A4 2014 from Evans Cycles
Specialized Tarmac SL4? Brilliant frame.
That Norco doesn't seem to have a carbon fork, makes it not so great value. The Subway is a hybrid, so quite different to a specialized road bike. I don't know what bike to work schemes Decathlon are signed up for, but there's this which is basically the replacement for the hugely popular Triban 3 Red:
http://www.decathlon.co.uk/triban-500-se-road-bike-black-id_8306187.html
