*** The Official Diablo III Thread ***
Status
Not open for further replies.
Did something happened tonight? I opened a rift and got d/c just as it opens. Couldnt rejoin for an hour or so, and got distracted with something else
Also yea bad drop recently even on higher Ts
Having D3 withdrawl symptoms.
Been away for 5 days and all booked up for the next 2 nights alongside working all weekend. Neeeeeeeeeeeeeed my fix!
its just a community feel really, it means you usually have a source of people looking to do rifts or bounties, and a bit of banter on chat.
Its a bit quieter at the moment as people are sorta takin breaks till the patch lands but its worth joining up if your interested in playing long term
There are regulars most nights:
F00 (me)
Fight
OverKill (clan leader)
Spanky
Skullface
Fallen
Syver
xdcx
Burok
MackLAD
Azer
+ more (sorry!)
Used to have more active more consistently, but as Sharpy said, most are taking some time out due to binge-playing or to give 2.1 a clear head!
I'm still offline due to knackered laptop. Waiting for a replacement gfx card to be shipped from the US but its an ebay special so may not work when it turns up!
I knew I shouldn't have swapped to a Radeon :D. Went from my 780 to a 290 for new toy reasons only and Diablo runs at what says is 60 FPS but every now and then it starts juddering even though the FPS is still 60. I'd say it's probably a little more juddery than your usual micro stutter.
Anyone on a 290 or 290X had the same and found a fix?
Leg drop rate been lowered? 3 hours on T5 and just one lousy plan. Just gonna wait for 2.1 now.
I've not had a plan in about 7 weeks.
Drop rate is all over the place; i've gone 2-3 T5-6 rifts without anything, then next 5 rifts I get 3-5 items.
It is random, remember that - and a little apparent trick is to not play for upto 24hrs, and then when you return your chance of getting a leg is improved immediately until you get one, then it resets. (Pity Timer).
Is this with V-sync on?
This might be true, I had a bad 2 weeks and rage quit for 1 week and the last few days I've gotten a lot of legs, normally its 0-1 for a run then 3-5 the next. Compared to those 2 weeks where I could go maybe 5 runs without a drop, not even a forgotten soul.
Status
