what did you think of the mr speaker Mad dogs?
or is that a pending review :O
That review is coming really soon
I won't say too much yet but they are quite impressive considering they essentually started out as a budget closed headphone.what did you think of the mr speaker Mad dogs?
I won't say too much yet but they are quite impressive considering they essentually started out as a budget closed headphone.Thanks, I've had a pair for over 5 years I've probably changed the pads twice in that time. A simple wash every 6 months in some sopey water or even a quick wash in the washing machine and a little clean every now and then when they get mucky. They should last you a long time.
Just throw the whole headphone in the sink or washing machine.I'll try and get a picture of how mine look. The cups are more of a dark grey now and look to have a bit of wear and tear on them.
Do you wash them still attached to the headphones or do you take them off and wash separately?
just remove the pads, wash them then dry fully then put the back on.What are your thoughts on K612 Pro vs K702 Anniversary, I'm after an open or semi open can with great midrange with warmish bass (not a bass can). Budget £500 max, I was toying with getting the Beyerdynamic T90 Jubilee Limited 90th edtn.
yeah we sell them too i think. :O
I'll check but pretty sure it's teh same spares
yes it is ET770V
Sure i can do something on the price![]()
DT770 added. I will be adding some amps today too.
