*** The Official Playstation 4 (PS4) Thread ***
I tried triangle last night.
There's no way to make my blu-ray stop stretching as far as I can see?
EDIT : It's just pirates of the caribbean that does it. John Carter works as it should :confused:
Both my controllers with newly fitted xbox one sticks.
Huge improvement!
(Check out the red ones Joe!)
Huge improvement!
See i told you if i could do it then you could! It isn't hard to do, it's quite easy just requires patience if your a bit cack handed.
Yup massive improvement over the normal sticks, makes the ps4 controller easily best one I've ever used.
If you're opening it up to change the sticks I'd be inclined to change the battery too. I've always preferred Sony's approach to including a battery with the controller but they really should have used a better one this time round.
Yes. It was pretty easy with the only anxiety provoking moment being when prising the front and back apart. But you can use a bit of force without any problems.
I would recommend it to anyone with original stick problems.
Like I said earlier chaps, if you dismantle your pads be careful not to lose the little rubber reset button out of the back. I notice a lot of YouTube guides don't mention this.
