P=V^2 / R
So
Power = (Voltage x Voltage) / Resistivity
So, in essence, whenever you change voltage OR power, assuming the resistance of the coil is the same, you change BOTH.
Example. You have a 1 ohm coil (for ease of calculation).
So, if you fire 4.2 volts over the coil you get (4.2 x 4.2) / 1 = 17.64 Watts.
Now, you can change the voltage to 4, so you get 16 watts.
Or, you could have fired a 1.5 ohm coil at 4.2 volts, giving you 11.76 watts.
Or, you could have changed the watts, say to 10 (on the 1 ohm coil). This would give:
10 = V^2 / 1
10 = V^2 (Multiply both sides by 1)
Root 10 = V
V = 3.16 volts
Had this been the 1.5 ohm coil, V^2 = 15, so V = 3.87 volts.
Basically, what it comes down to is a balanced equation. You have 3 variables, resistance, power and voltage. When you make adjustments, the resistance stays the same, as it is the same coil. So whatever adjustment you make, Power or Voltage, it affects the other variable such that the equation remains balanced.
This is a basic misunderstanding of the physics behind the device. When you change two variables, only the last change is viable. So vaping at 10.5 watts, then changing the voltage, means you are putting out whatever power is given as a result of the voltage across that coil. Yes, you can change either Volts or Watts, but it is the LAST change only that is relevant. It COMPLETELY negates any change to the other variable. When you swap from voltage to power, you are changing the power to give a certain voltage over the coil, and you are in Power mode, NOT voltage mode. And vice versa.
In this instance, assuming he changed wattage first, then voltage, as his statement reads, he actually would have been vaping at 4.8 volts, and 4.1 volts. The ACTUAL power (wattage) he was vaping at would entirely have depended on what resistance coil he was vaping at that voltage.
Similarly, if he had changed voltage first, then power, he would have been vaping at 10.5 watts, and 8 watts, with the voltage applied to the coil completely dependant on the resistance of that coil, at that wattage.
EDIT: It is also a dangerous game rebuilding your own coils when you haven't really grasped the basic Physical concept of what is ACTUALLY happening. You SHOULD be okay on mainstream VV / VW mods, as they wont fire a low resistance coil, but make sure you UNDERSTAND what you are doing if you decide to throw a build on a mech mod that doesn't have any protection circuitry.
Depends on what it is. Fruity / drink type ones I find are good to go right away (But better after 2-3 days)
Food type ones around a week.
Also depends on where you get the concentrate from etc. But that is pretty much what I do with all mine.
My first Sleeper coil (all one wire)
Damn it hits hard!![]()
P=V^2 / R
So
10 = V^2 / 1
Root 10 = V
V = 3.16 volts
Hard to make or hard to hit? I'm tempted to try it.
This is a great explanation. I've got a basic grounding in electronics and the whole variable wattage claim of these ecig batterys always got me thinking.
I must admit being a bit of a dumb ass I though vw ?, wth is that... as you can't vary that without varying voltage on a fixed resistance coil. After more thought I guessed the only way of true variable wattage was some kind of PWM modulation (which I believe some crack pots tried on one unit on market)
It makes sense to me now after your explanation, but the description VW though true is misleading... should be called 'AV' ... auto voltage![]()
I'm going to keep this brief. I can't handle reading through this monster topic because it is full on acronyms I don't understand. So apologies if this has been done countless times before but, spec me a vaporiser please! I want to quit smoking and I watched a video of someone smoking mum's custard (sorry, vaping). Looked like a good way to give rollies the boot. Cheers!
