Hmm maybe I should ask on here before I place order for new build, see if you guys can make anything better?
Ask stulid to spec you a build
Ask stulid to spec you a build![]()
Always, get as much input as you can![]()
I'll put it in general hardware I guess?
I personally wouldn't recommend two PCS cards unless you can get a really big gap between them.
Hmm I can get Tri-x's for £550, shame I'd lose the free ram![]()
Its a big case so plenty of room in it, its just a shame the motherboard is not that long, one with 4 16x PCIe slots so you could put one in slot 1 and the other in slot 4... i think they would have enough room to breath.
The MSI's are fine ^^^ they had fan troble in the past but i think that has now been sorted.
X97 here with 4. though while its states x16 it says its running at x4? i don't get that, its either 16x or its not?
Also has free RAM...
We need Matt to see how Slot 4 works with the 290's
Doesn't XDMA suffer performance loss when running through lower end PCI-E lanes? Pairing 16x with a 4x lane for CF.Its a big case so plenty of room in it, its just a shame the motherboard is not that long, one with 4 16x PCIe slots so you could put one in slot 1 and the other in slot 4... i think they would have enough room to breath.
That'd be x79 though right?
Is the MSI 290 decent? just thinking it'd fit the colour scheme
Thanks Matt, so the third PCIe on that MOBO should be ok?
@ Thefogo, is the third PCIe enough room for the PCS+ do you think?
The 3rd 16x slot on that board is wired for 8x, so CF will run 8x/8x in 3.0...so yes, would be fine.
As for spacing, how much does he need? He'd have 1 slots gap between the bottom of the first card to the top of his second card (if running 3 slot cooler, the PCS) He's also running it in a decent case for air cooling. Should be good to go.
Now it's whether orange will work in his colour scheme
