Can do that for you no problem. But we need a budget for you. What are you willing to spend? It's not necessarily that the more you spend, the better the "hit" or whatever, but there is a price-point where it REALLY starts coming together.
However, that price-point is at a place that I wouldn't have been happy with to "try" vaping. If you think you can give it a proper go, then spend the money right first time. If you are just wanting to see "if it might work", then we can suggest cheaper options.
This is great advice. I got a evod to start with. Endless problems with leaking and it put me off. So I bought a more expencive top bit (not sure of the name) and its miles better. But then the hit wasn't that good so I've bought a better battery, now I want something better.
So I would say spend a little more than you would really want to. If you start smoking you could always give it another go or even sell what you have bought but I doubt you would get much back tbh
So in total I've spent around £40 but its a ok bit of kit I have but if I had of just spent the £40 first time round then maybe I would have something a little better than what I have now
