Yeah, x79 slow to boot in my experience.
Z97 can be near instant if have all fast boot stuff enabled and hibernation.
So much so, I actually turn my PC off rather than sleep sometimes![]()
Better internal TIM maybe
I'm using regular LLC! I seem to be getting a lot of overvoltage, hence the negative offset. I may have to start using manual voltage if i can't sort it. As an example using 46 turbo and offset at 0 voltage is up at 1.45v. Any suggestions? I'm using cpu limit of 180%, could that be why?
Refresh interval can probably come down. Wouldn't worry too much that's pretty tight enough
All 2011 chips are soldered TIM. You get ones with better contact though
Cpu limit leave at 130. What else is left in auto?
