Just thought I would share with you some (not very good) photos of my in progress build.
Phenom M, with a Strider 850W Gold PSU (shortest psu, suits the case very well)
Gene Z97
512GB Crucial MX100 SSD
2TB Toshiba 7200 HDD
Dark Pro 3 (not pictured)
On Order:
i7 DC
16GB Kingston 2400
GPU: Not yet sure...
I have made some modifications to the front panel, including drilling a lot more air holes down the sides behind the meshing, and removing the bottom obstruction. I've fitted two slim fans in the top section which do not obstruct the inside of the case, and two fans at the bottom, both the top and the bottom fans draw air in to the case. All are filtered. The rear is a 140mm exhaust. I've also swapped the side panels around so the cables don't come across the case.
I fitted the board just to see how it fits, and to make sure the Dark Pro 3 fits. It does, but it is very tight, up against the hard drive panel. I could put the hard drives in the bottom, but I want the fans to bring in air.
Gene Z97
On Order:
i7 DC
16GB Kingston 2400
