No the 290 will run at about 40C idle and 94C load.
Do you not have another pci-e x1?
I might go down the ebay route for a change, as I can get a msi 290 with the 1 fan blower version for about £200 instead of £330 new, but the problem is, do you trust what ppl put,,, ummmmmmm?
What's going in the x1 slot?
Since you already have a soundcard, what could you realistically see going in there that would make you go for a loud ref cooler over a good non-ref card?
There are 2 slot non-ref cards out there too.
Im guessing the cooler on the 290 card will be more or less the same as on my 6950, and if thats the case I will be happy?
Its back to the drawing board, I have cancelled the msi 290, and hell with the pcie x1 slot, I'll cross that bridge if I buy a pcie x1 card.
Im still after a 290. I was thinking http://www.overclockers.co.uk/showproduct.php?prodid=GX-219-XF.
I was thinking if I could get a 290 that has real low temps, I could still use the pcie x1 slot, yeah the card will prob be covering up the first fan, but the temps shouldnt be shocking tho?
