Gallardo is bad on UK roads in my opinion.
Worse ride quality than the GTR was, very cramped inside, killer servicing and maintenance.
Plus the pre LP models look very dated now.
With my "budget" I could have bought a used LP570 but I am glad I had a good drive first because unless you have perfect roads it is horrible. E-Gear is total crap also and good luck trying to find a used manual!.
Then if you do find a manual the pedal offset is nuts due to the wheel arches (really meant to be a LHD car).
Look at the R8 V10 with a manual gearbox and if you are over 6ft don't bother with the Spyder as the roof folding mechanism means it has 2" or so less leg room than the coupe.
One month until my R8 starts getting builtand I am still happy with my choice over everything else up to ~130k ish.
I thought you already had the R8?
Also I don't know how similar the R8 and gallardo are (some people say they are the same) but the pedal offset is not existent on the R8?
However the most important question is, are you a powerfully built company director
. Loads more road presence than a Lambo and you can earn money with them too.
