- 13 Jul 2004
- Stanley Hotel, Colorado
If silver is basic then I need to get ranked up, I should be higher![]()
It can be basic beginner level or silvers can be good as nova I think, in a pub game a good silver will be top fragger np. It varies massively but basic is the general perception for comp.
My last game on Rush our team was silver and me as nova 1 and we beat the nova 3 team almost every round
cache tips - http://www.twitch.tv/52arya/b/561595031
I think this explains why the first shot has to be hs a lot of the time, to do well
Originally Posted by csgoPROuk View Post
if you have high ping will people with lower pings kills you first?
Yes Ping is the time for information to get to the server and back. Measured in thousanths of a second. 200
ping = 0.2 seconds or 1/5th of a second.
If you have a high ping you will often notice that your shots are not registered because the server says you
were dead before you fired it. You mostly notice it by being moved back to a place you thought you had passed
to die.
If someone with a low ping fires at you at exactly the same time as you fire back at them. You will always die
and they will be fine. By the time the server receives the shot from you, it has already registered the other
shot and you are dead.
You might think 0.2 of a second is not long, but an AK will fire 2 extra shots in that time(600RPM).
mm_dedicated_search_maxping
Seemed to work, never would in a random game but I could see it doing well if not repeated too often
They have to sanction kicks. Its used to avoid losses afaik (nobody knows elo exactly but imo) and also the common 4 man pre made kicking the 5th for a bot especially a lower rank player/non smurfIf 4 people vote for a kick, then I think I shouldn't get the ban.
