Ah right, thanks, so the heat link is just a step down transformer? They could have made the UK nest 240v!![]()
Does it come in through the FCU? So do I just need to splice into the white wire on the left? Thanks.
Had our old Potterton/immersion/tanks etc ripped out and a shiny new Worcester Bosch 29CDi installed over the weekend. Nipped straight out and picked up a nest to control it all.
I've not read the instructions yet. Was getting tired last night and the concentration started to wane!
Am I right in thinking I take the 230v going into the boiler and plug that into the Nest, and then the Nest into the boiler? Effectively putting the Nest in line? Or do I need a seperate supply to each and then just run a call for heat wire?
Is anyone finding the ambiant temperature reading to be off?
Mines reporting 23*c even though its 14*c outside and the house is clearly cool...
Just as an update - Npower seem to be giving these out for free if you sign up for a tariff -looks like the get out clause of the tariff is £50 per fuel so £100 to pay if you get one installed for free and then leave!
How are people finding their Nest? I keep looking at one but my biggest issue is I have rooms that get hotter than others. My living room has two big radiators so rooms like the hall way (where I would put the Nest) is much cooler.
