- 25 Mar 2004
- Fareham
Been trying out the Monk changes, they are very nice and I'm happy with them. Can do T6 without any problems at all now, whereas in 2.0.6 T5 was pretty much the limit and even that was dubious when it came to efficiency over T4. Had a quick go of a G29 and had no problems, finished it with about 4 minutes left.
Really do need a pair of Crudest Boots though, and need to get some of those fancy new gems as I'm just doing stuff in my old 2.0.6 gear since I've had no luck with drops today.
If any one wants to add me: Teaf#1614
Jelly![]()
Difficulty really ramps up after GR 30 or so, each level above supposedly is about 20% harder than the one before it.
The other thing that bothers me personally is the randomness with respects to mob types you can get, packs of corrupted angels or those rock guys who take no damage can really ruin your ability to complete a run.
The best I did on the PTR was grift 35 with shotgun build, but shotgun simply seemed to let me stutter step better on the PTR than in live (rubber band a lot) so not sure I would hit the same level on live, maybe 32 or so without good stutter stepping.
