Thanks again dude. Super helpful. I might just buy some wire that's not pre done so I know the exact mm that way ill learn more in the process as well...... hopefully![]()
How many people's locals have banned indoor e-cig smoking? I've been to 4 different pub in the past couple of weeks and 2 of them told me I couldn't smoke them indoors!
Just spoke to the guys in my local vaping emporium, 0.30 guage wire & 5 to 6 wraps for the micro coil wound on a 1.5mm dia peg/post.
Hope this helps you out?
Cheers
That's going to get you a very low ohm coil - probably little more than 1 ohm, which some batteries and mods will struggle with (if even fire).
When rebuilding Protank heads I use 9 wraps of .3 kanthal on a 1.8mm driver compressed to a microcoil for about 1.6 ohms. This gives you good coverage of the wick and works brilliantly on anything you put it on.
Find my rebuild tutorial in this thread here: http://forums.overclockers.co.uk/showthread.php?p=26212200#post26212200
Would someone care to recommend me a nice and reliable RBA please?
Got two KFL's.
One is an FT clone (no adjustable airflow) which actually gives a better vape than my other KFL, but it tends to flood when filling and takes a while to stop leaking out of the airhole. It can also leak out of the drip tip when filling too, as the seal doesn't work properly, despite the oring.
The other KFL is ok, but the airscrew is stuck at the outer position and it gives a noticeably tighter pull. I'm happy to keep this as a spare and for out and about duty.
May also be looking at a T5 and am having a hard time deciding on an RDA for cloud chasing ****s and giggles![]()
Cheers.
