hmm, I'll keep checking then, haven't got it where I am still. Annoying, Telewest skipped our part of the road too.
Which county are you in?
Got Infinity yesterday
... 6.5Mbps downstream
On ADSL we got about 3.5Mbps downstream from an attenuation of roughly 50dB. Attenuation on Infinity is 29dB (line) / 22dB (signal), but getting 6.5Mb down and the same crappy 1Mb up!
Line attenuation: 0.0 / 29.2
Signal attenuation: 0.0 / 22.8
Data rate: 1156 / 6558
Maximum data rate: 1164 / 6477
Noise margin: 6.5 / 6.1
Surely something is badly wrong here?
snip
Yes, report that to BT and pray they send a worthwhile engineer your way.
My story is becoming long in the tooth now, tempted to give up.
So the Infinity recap is :
-Ordered on July 28th
-Scheduled for August 12th install
-No engineer 12th
-No engineer on 14th rebook
-No engineer on 15th rebook
-Engineer on 18th rebook can't find our tone in the cabinet, claims he called it in and couldn't tell us any more - wait for BT to call is his best advisement.
-A call to BT that evening, with some strong language resulted in it being turned over to their RESOLUTIONS department(I kid you not. It drips with sarcasm), whom assured us this would be taken care of - sending Openreach to do a line route check on the 20th.
-No engineer on 20th
-Engineer (not sure if scheduled) arrives on 21st apologising for us not having a phone line. He was confused to find we in fact did have one the whole time(was down for two hours back on August 12th, no problems there). He left to find our tone, took him ten minutes at the correct cabinet. Said he'd called it in and Infinity engineer would come by in due course to finish the job the following week.
-Unknown to us in the meantime, two engineers did a full route check (as apparently the above one only did a half check?) and they claim line is fine, all working.
-Engineer arrives on 28th, calls us forty minutes later saying he cannot find the tone - turns out he's at the wrong cabinet (the one BT keep sending engineers to improperly). We tell him where it should be and he confirms that's correct - he remembers doing our neighbours so to him it makes sense. He identifies that our fibre is connected to the wrong cabinet and calls it in, opening a twenty-four hour change over request. He promised to be back the following day to finish the job.
-No engineer 29th
-Case handler is out of her head at this point, extremely annoyed with Openreach and comes in on Saturday to try and make a personal plea to a colleague she knows well. Apparently this case goes way up the chain and is being looked at by senior staff on Monday.
All in all, there's multiple things going on here that just make the entire experience fatiguing. The laughable/cry-able part is where three different engineers all claimed the line and connection was fine.
I'm not sure what the moral or lesson in this is, but one tip for any one looking at internet service, make sure to check availability and speed estimations using your neighbours addresses as well. If you find that you and them have wildly varying results like I did, something might be wrong.
Had the same issue as you, the Openreach database had us down on a different cabinet to the one we were connected to. The order with BT Retail silently failed and none of their overseas people could explain why or give any indication as to when the order might progress (it must be a cultural thing that the Indian call centres would rather keep apologising and express how frustrating it must be rather than saying what went wrong and what they are hoping to do in order to fix it). Anyway, it ended up going through their executive level complaints team and was resolved about two weeks later than the original install date.
I am not sure what you mean by seems close enough. To get FTTP you need BT to have laid FTTPp). FTTP is currently extremely rare, coverage of FTTP is very small indeed.
Accepting Orders
You are connected to the Cwmbran exchange.
The first homes and businesses in your exchange area have been connected to fibre broadband, however not all premises can go live at the same time and work will be continuing in your exchange area.
How much are you paying for the 40/2?
I'm confused by the Superfast cymru site, i've put my postcode in, selected my correct address from the drop down box and comes up with the following
From that instance I see "Accepting Orders" Check BT and says its unavailable.... Seriously confused...I WANT MY FIBRE DAMNIT!
