Caporegime
- 18 Sep 2009
- Dormanstown.
Not impressed if those reviews are anything to go by, it has same performance and power consumption as the 280, it costs the same despite having 1GB less vRam.
Basically, they haven't improved efficiency at all, removed a third of the vRam and then slapped the same price on it it as the better GPU its replaced.
Its a backward step. even saying it has the same performance as the 280 is a little generous. its a 200 Watt GPU with similar performance of the old low clocked 7970; 200 Watt GPU.
And you had such high hopes for it ; 780 performance.
On a serious note, I actually have a more positive response to it than you (Beside price)
